Its page and the "Datasheet" link sure make it sound great.
From everything I've seen of Kontronik it'll be pricey, but 45-cells nimh or 15s lipo, and 120A with 200A max is right in-line with what some of you guys aspire to :003:
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
I wonder how they do the no spark plug. The others spark from charging up the capacitors. Yeah thought and still thinking. ;) I can't say yeah or nah for the fact I have not talked to anyway that has tested them.
Peace!
Country
Help support the
Rc-Monster Buy here
That spark is almost certainly the inrush current from the capacitors charging. If the spark really bothers you, connect the grounds together and then use a 10 ohm resistor (~5w) between the power wires. This will make the caps charge slower by reducing the current. Leave it on for about 30 seconds. This time really depends on the total capacitance value, but 30 seconds should be more than enough. This is a common procedure when charging MUCH bigger car audio caps (1,000,000uF or more). The sparks from that big of a cap can leave some pretty bad scorch marks. The ESC caps are much smaller.
