Mamba Monster Amp rating?
Dj_Sparky
Mamba Monster Amp rating? - 08.01.2010, 09:52 AM
I was wondering what the BURST rating of the Mamba Monster AMP is.
nuz69
nuz69's Avatar
08.02.2010, 05:44 AM
Something like 500 or 600 amp ? Depends of what you call "burst".
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Dj_Sparky
08.02.2010, 06:27 AM
Was looking around at some info on what sort of amp rating the 1527/1y might kick up to, so I was just wondering about the burst rating of the mamba monster amp and what it could handle in worst case scenarios.
nuz69
nuz69's Avatar
08.02.2010, 06:42 AM
The amp draw doesnt depend of the motor but of the application. A 1527/1Y will not consume the same amp in a 1:8 scale buggy or in a 20 lbs monstertruck, depending of the gearing and the acceleration ...
Anyway, the max continuous current of the 1527/1Y is the same of the 1515/1Y and of all the 15xx/1Y series. But its not the current that the motor draws, it's the max continuous current that the motor can handle without burning.
Dj_Sparky
08.02.2010, 06:47 AM
Ah ok, thanks for clearing that up. I'm waiting for info on the diff ratio and final ratios etc on the Genesis differentials and transmission, but in the meantime I checked out the Flux tranny and gears with 12 pinion and 60 spur, aimed at 30mph top speed and 3 second to get there, and it only drew 30 amps. That would be a nice setup, sort of slow but ah well.
I'm guessing monster truck differentials are somewhat similar, so I'm estimating that I should be safe with a low pinion like 12 and 60 spur.
nuz69
nuz69's Avatar
08.02.2010, 06:53 AM
Best solution is to try, don't hesitate to use punch control, it reduces a lot the spikes during kick-downs. Start for example with 80% and gear the truck for 30-35mph. It will be on 6S ? What the average weight of the truck ?
Dj_Sparky
08.02.2010, 06:54 AM
Yes, 6s and it will probably weigh around 18lbs once I've installed everything. Waiting for the stuff still.
nuz69
nuz69's Avatar
08.02.2010, 07:01 AM
I am pretty sure you can gear it for 35-40mph without issues. The mamba monster can handle the amp draw of a E revo (11lbs) geared for 70-75mph on 6S.
Dj_Sparky
08.02.2010, 07:02 AM
Sounds good. A 18lbs truck running around at 75mph would be a little scary.. haha. :p
Should be possible with the 1527, no ? But I'm guessing I'd need a veery special esc. If anything can handle that.
nuz69
nuz69's Avatar
08.02.2010, 07:22 AM
With proper cooling, and BIG BIG BIG ESC everything is possible. But without cooling a 1527/1Y should do anyway some speed runs at more than 100mph without overheating and with the proper ESC. All we need to do is to check the temps.
pinkpanda3310
pinkpanda3310's Avatar
08.02.2010, 08:18 AM
Originally Posted by naynay12 View Post
Hopefully the tranny wil hold up with the cc2200kv which i plan to use.
Howmuch amps does the cc2200kv pull?
From our testing about 200A on 4S and 350A+ on 6S during acceleration. Average draw at top speed is about 50A on 4S, and about 80A on 6S (at 50mph.)
This is from a thread about a savage. I know there not firm numbers but it might give you an idea.
Dj_Sparky
08.02.2010, 08:25 AM
Ok, thank you. Looks like a 12 pinion on 6s with mamba monster will be fine then.
nuz69
nuz69's Avatar
08.02.2010, 08:30 AM
In a 1:8 scale buggy, the power needed during acceleration to top speed (40mph) was 120-130A on 4S. The savage is a lot heavier so the measurments correspond.
