Turnigy Lipos 5200mah 2s2p, not 2s1p?
Muggydude
Turnigy Lipos 5200mah 2s2p, not 2s1p? - 09.09.2010, 09:36 PM
Hey, i opened up my turnigy 2s 5200mah 30c hardcase lipos because the case came unglued. And it appears there are 4 cells inside? Is this correct, or should there only be 2?
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
Freezebyte
09.09.2010, 09:53 PM
Hmm that's odd as I have the same ones though I haven't cracked mine open
http://hobbyking.com/hobbyking/store...dProduct=10277
Spec.
Minimum Capacity: 5200mAh
Configuration: 2S1P / 7.4v / 2Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
Pack Weight: 333g
Pack Size: 139 x 46 x 26mm
Charge Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
09.10.2010, 04:05 AM
pic needed.
Have you seen a lipo pulled apart before? I bet you are just seeing folds of the individual cell and assuming its 2.
Regardless, it doesn't matter if it is 1p or 2p. It all works the same.
bruce750i
bruce750i's Avatar
09.10.2010, 10:28 AM
They do sell 2s2p 5000 hardcase packs. What is it labeled as?
reno911
Smelly Nitro meet your maker!
reno911's Avatar
09.10.2010, 10:41 AM
I am pretty sure turnigy sells both a 2s2p and a 2s1p 5200 mah. Freeze posted the link to the 2s1p.
Makes me wonder though since the dims are awfully close, I couldn't find the 2s2p turnigy, but here is the 2s2p zippy
http://hobbyking.com/hobbyking/store...idProduct=9966.
I still own one of the 4 of these Zippys. I should get some pictures for you all. It poofs like crazy, ripping apart the too plastic halves when venting. Still works though. I am going to run it to its death, like its 3 predecessors.
Get us some pics muggy.
Freezebyte
09.10.2010, 11:45 AM
These
http://hobbyking.com/hobbyking/store...dProduct=11614
