3.5 mm bullets on 1406 motors?
ksb51rl
3.5 mm bullets on 1406 motors? - 11.11.2010, 06:19 PM
The pdf image on this Neu - Castle 1406 motor page (actual pdf link not working) shows the motors to have 3.5 mm bullets. I realize the smaller motor systems use the 3.5 mm connectors, but AFAIK the 1:10 and larger systems use 4 mm or 6.5 mm bullets. Why the change and which Castle Creations ESC are these motors supposed to plug-n-play with?
bruce750i
bruce750i's Avatar
12.29.2010, 11:45 PM
The neu-castle 1406,1410 motors run 4mm connectors same size as SwSct, MM & the MMP esc's use.
whitrzac
Can't catch this...
whitrzac's Avatar
12.30.2010, 01:56 AM
I ran 3.5mm bullets in a 1/8 buggy...(5s/1400kv)
404 error problem not found...
Pdelcast
Pdelcast's Avatar
12.30.2010, 05:11 PM
Thanx for pointing out the error! That document should show 4.0mm connectors, not 3.5mm.
Patrick del Castillo
President, Principle Engineer
