I'm looking for a bearing that measures 8x17x6mm. (17mm diameter, 8mm hole, 6mm thick) I can't seem to find one anywhere. I've looked at ebay, avid, bocca, and acer. I need four for a project on my e-revo.
Any suggestions?
Edit, I was able to find my desired size on google, but they are $25 a pop............
You could use a shim (aluminum foil) around an 8x16x6 bearing which is more common.
Edit: 8x19x6 is also common...
Good idea, but these will be the outer wheel bearings in the revo knuckles. Not sure if I want to go that route. Now why did Hot Racing have to go and use a 17mm bearing.
Wait...which HR knuckles? The only ones I see on their site use the 6x13x5 bearings...
I'm not sure the style I have is made anymore...can't seem to find them anywhere.
The knuckles I have use 6x17x6 bearings. I'm wanting to use Losi XXL driveshafts. That's why I need the 8mm bore. I wouldn't mind using a 8x16x6 bearing, I just wouldn't want to shim it with aluminum foil. Is there a better shim option out there? I'm not sure if a metal sleeve that is .5mm thick and 17mm in diameter exists?
