Center diff camera mount ideas?
simplechamp
simplechamp's Avatar
Center diff camera mount ideas? - 02.20.2011, 04:36 PM
Since there is much more room inside of a 1/8 GT body I want to finally play around with my FlyCam and get some on-board video. I would like to have the camera looking directly out of the front windshield, and placing the camera at the center diff will allow this.
My concern is that making a platform high enough to see out of the windshield is going to require some fairly long L-brackets (attached to the brake mounting holes). I am wondering if these will amplify any vibrations and cause the camera to move and shake. So the idea I had is to use small pieces of fuel tubing or o-rings on the mounting screws. Also maybe put a piece of foam under the camera?
What do you guys think, will this work? Or should it be fine without that stuff? Or should I scrap this idea and find a different way to mount the cam altogether?
Jahay
02.20.2011, 06:31 PM
i dont see why that wouldnt work... the camera is lightweight isnt it? So it should be all good!
pinkpanda3310
pinkpanda3310's Avatar
02.20.2011, 06:35 PM
I wouldn't use the fuel tubing or anything that will give it flex. It will have the opposite effect of what you want. Just screw it down as best you can.
Jahay
02.20.2011, 06:38 PM
+1
you could just put the camera on some foam to absorb any shock and zip tie it down?
simplechamp
02.20.2011, 08:31 PM
OK I will try it with no o-rings and see how the video looks. I do plan to mount the camera with 3M double-sided foam tape so maybe that's all I need. The camera is very light Jahay.
EDIT: Here is a pic of the camera. It has a base/pedestal type of thing underneath the camera that you cant see very well, but that is where the cord plugs in. I haven't tried to control it with my transmitter yet, but I don't think it will be too difficult to get working.
