rebuilding a 5700 two pole motor
mwe-maxxowner
mwe-maxxowner's Avatar
rebuilding a 5700 two pole motor - 10.11.2013, 09:51 PM
I have a mm with a 2 pole 5700 geared 15/90 in a 2wd stampede that I run on 2s and 3s. Power is insane, but it likes to get hot.
Would a 4 pole 5700 run cooler?
Is this motor rebuildable as a 4 pole?
Does the 4600 have similar characteristics on 3s?
I love the truck like it is. The thing screams and will pull the tires up all the way to 50 (guesstimated).
Brushless-taking back rc!
E-revo is DONE!
  Send a message via AIM to mwe-maxxowner
phildogg
phildogg's Avatar
10.12.2013, 01:33 PM
I'm not sure you can get the rebuild kits for the 2 pole motors anymore, you would be better off with the short course 3800 4 pole on 3s. motor has alot of power and runs cool.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
mwe-maxxowner
10.12.2013, 08:56 PM
Does it have enough torque to gear up to speed similar to my 5700 and still pull wheelies at any speed? I'm kindof addicted to that :D
If also considered the 4 pole 4600 and 5700. Is there much difference between the 2 pole and the 4 pole, running hot wise?
I was just wondering if the 4 pole rebuild kit worked on the 2 pole can. I don't know a whole lot about the makeup of these motors.
E-revo is DONE!
10.12.2013, 09:32 PM
The CC 2 pole and 4 pole motors are not even close to the same. Just about the only things common between the two is that they are both in a can form factor, both have a rotor shaft, and have wires sticking out.
mwe-maxxowner
10.12.2013, 09:59 PM
Could I expect a 4 pole 5700 to run cooler on 3s than the 2 pole, or just find another setup I like?
I just already know I love this truck with the 5700. It hasn't let up yet, though.
E-revo is DONE!
Dadx2mj
Dadx2mj's Avatar
10.14.2013, 09:53 AM
My 4 pole 5700 does run a little cooler than my 2 pole but not a huge difference in heat, the big difference is in power and torque. Also the 4 pole 5700 makes my MM ESC run very hot, much more so than the 2 pole does.
Blindman Racing
Powered by Mamba 5700
mwe-maxxowner
10.14.2013, 01:37 PM
Okay, then that's a no go. The ESC is most important to me. These 1/10 motors are getting cheaper these days, but this ESC is too good to blow. Maybe I'll try a 3800 and see if it can be geared to my liking. In the meantime I'll see how much abuse this 5700 can take :)
E-revo is DONE!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.14.2013, 05:39 PM
If you like what you have but fear excess heat, drop a 5v fan onto the motor and power it with a servo lead from the receiver. Cheap insurance. :)
mwe-maxxowner
10.14.2013, 08:49 PM
Heatsinks, fans, all already in place haha. I'm gonna try wiring a fan to full battery power. Little fans are cheap!
E-revo is DONE!
Dadx2mj
Dadx2mj's Avatar
10.14.2013, 11:27 PM
An aluminum tranny case in that Pede will cool the motor, IMO better than a fan and will last a lot longer. The FLM tranny case in my Rusty dropped motor temps 30º
Blindman Racing
10.14.2013, 11:32 PM
Adding a cap pack and external BEC will lower temps a lot.
I would get a 4 pole 4600kv or one of the 3800kv SCT motors. The later were really cheap.
mwe-maxxowner
10.15.2013, 08:41 AM
Wow! 30°, that would be worth looking into!
I also had no idea an external bec would help cool things down. Not sure if I'm proficient enough with soldering to add a cap, but becs are easy and cheap. I may do both, and if the motor ever does lay down on me try a 4 pole 4600.
E-revo is DONE!
