More Speed!
neweuser
neweuser's Avatar
Talking More Speed! - 07.06.2006, 09:55 AM
Ok, i have been pondering on a few things. I love my 10xl motor. I really like it with a 20T pinion. The problem though, geared that way, it's way hot and starts stuttering. So i run the 18 and it seems fine, but not enough speed for me i guess. I really want a motor / controller that can fly but stay cool on 16 cells. Any suggestions would be great. Or, if i change my controller, can i gear it up to get more speed, or would it be too much for the motor then? I want a good combo for speeds that won't get too hot! thanks!:032:
squeeforever
squeeforever's Avatar
07.06.2006, 10:26 AM
Yours gets hot with a 20T!?!? I run 20/51 with stock diffs! Thats pretty odd. I would stick with a XL motor unless you are gonna get a 1950.
neweuser
neweuser's Avatar
07.06.2006, 10:32 AM
Well, I know my controller does foresure, I haven't taken a temp gun to the motor yet. But my capacitors on the controller damn near pop with the 20T. It gets reall jerky with the 20T after about 5 min! Let it sit, then it goes like a batt out of XXXX, then gets stuttery (fine line to thermaling i think). But i also run UE diffs. So the 10xl can go FAST, just need a better controller to handle the temps better?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
07.06.2006, 10:49 AM
I don't think your controller is the issue, I think it's fine along with the cell count your running....the 19 series motors will work for you, i think you need to keep your rpm per volt around 2500 or less for the amount of cells your running, this will put you in the 40,000-50,000 rpm range on the motor. the big question is how to gear it for the speed you want without thermaling your system.
  Send a message via MSN to sjcrss
neweuser
neweuser's Avatar
07.06.2006, 10:56 AM
And that's the problem sjcrss, when i gear it to the speed i want, my 9920 gets too hot. when i gear it down a few teeth, my temps are good, but i have too much torque and not the speed i want....so my thinking was, if i got a btter controller, i could use the 10xl for the speed i want and gear the way i want, just need to watch the motor temps. the motor on the 20T was a tad hot, but the controller was woohoo hot...even with a fan on it!
Any other ideas guys how i can obtain my speeds?
sjcrss
sjcrss's Avatar
07.06.2006, 11:13 AM
I to would like to have more speed, but at what cost...bringing your controller to the brink of thermaling or thermaling or even a controller failure, you need to find a happy medium, I know it's hard, Well I've ran my system for 4 years and never had a issue with thermaling or anything, even after i switched to the UE diffs last August....the 9920 isn't much differant than the 2095 micro I'm running, other than the micro is programmable and the # of amps it can handle..the cell counts are the same....so the controller isn't the issue, it's the low rpm per volt on your motor...
neweuser
neweuser's Avatar
07.06.2006, 11:21 AM
Well, I'm currently running around 28,000 rpms (i believe) maybe 30,000 right now with the 16 cells, and my controller is getting hot. If i go with a higher rpm motor, will that keep my controller happier? Is this right? It just seems that i can't gear this thing the way i want without frying my 9920!
neweuser
neweuser's Avatar
07.06.2006, 01:49 PM
Ok. So with all my calcs, i can't seem to break the 40 MPH. I guess I will need LIPO to do that, the 16 cells just won't punch it. 1930/10T 16 cells: 16/51
40128 RPM
34.49 MPH
20/51
40128 RPM
43.12 MPH
But i think the 20 will be a tad hot....you'd think with 16 cells you could really push it faster, but guess not. Any ideas besides Lipo? Put a sail on it perhaps?
07.06.2006, 02:04 PM
What is the gear ratio of those diffs, or are they like a normal emaxx? I assume you are locked into 2nd gear on the tranny? How much does your truck weigh?
neweuser
neweuser's Avatar
07.06.2006, 02:23 PM
My truck weighs(with the cells) about 12lbs. I run a single speed tranny(2nd only). My diffs are the UE buggy's, not sure the ratio....
squeeforever
07.06.2006, 02:24 PM
I would NEVER run a motor over about 40k rpms. Thats getting out of the efficient range. Stick with somewhere around 35 to 40k....I think there might be a few FET's on your controller went bad...
Hustler
Hustler's Avatar
07.06.2006, 02:29 PM
Guys, Just curious, what would happen if he uses a 7xl motor instead of his 10xl, and with a 20T pinion...!!!
neweuser
neweuser's Avatar
Is there an easy way to tell about the fet's?
Hustler: It would run way tooo hot!
jhautz
jhautz's Avatar
07.06.2006, 02:41 PM
I agree with you for the Feigao and wanderer motors. They are rated at 50K max. But you should be able to get way with more rpm from the Lehner motors, They are rated for 65K rpm max. I would think you could run it up to 45K easy without loosing much effiency. I could be wrong, but just my thoughts.
to make it...
or break it...
Silent...But Deadly
neweuser
neweuser's Avatar
07.06.2006, 02:43 PM
Ok. I have a thread on presales about a quark....can someone check it out, i'm gonna run that with the Lehner motor.
