??9920 and plastic center gear?? -
10.17.2006, 10:51 AM
I was curious about when the BK warrior 9920 controllers would be back in stock cause I know they have been on backorder for quite awhile. Unless I just miss it when they are in.
And I also am looking for a plastic spur gear for my hellfire, it uses a center diff and I am having a hard time finding a gear that I can use with it and my brushless motor.
Thats not wise....They still don't last for some reason...MacII went through several...The plastic spur Rene mentioned is what you need. It should bolt right up..
Why is that I wonder? After all, the stock Nitro engine uses a hardened steel clutchbell. :032:
If you are referring to the Century motor gears from Tower, I would recommend against them. They are not that 'hardened' - I have gone through a 14T gear in about 45 minutes of driving.
I hate to mention the name here, but CF of FD uses a true hardened Mod1 clutchbell with a 5mm mount epoxied in place that may add just a little weight at the motor, but I have been running one in a Kyosho MP7.5 conversion with a metal spur with no problems.
“Everyone has a right to be stupid; some people just abuse the privilege.”
