Successful buggy conversion!
Rcaddict
Successful buggy conversion! - 11.22.2006, 05:13 PM
GlassDoctor is da man. After reading some of his posts about his brushless 1/8 scale vehicles, I was inspired to convert my MBX-5 to brushless. I read everything I could on RcMonster and went with the setup recommended by GlassDoctor. Let me tell you, that setup was dead on. The buggy performed above and beyond my expectations and I couldn't be happier with it. I went with a Neu 1512/2.5d motor, Mamba Max ESC, UBEC, dual 2s6000 MaxAmps Lipos in series and a 14/46 gear ratio. Mike made up a custom motor/diff mount that was a work of art and allowed me to run the Kyosho 46 tooth spur. Thanks Mike, GlassDoctor and everyone else on RcMonster that helped me out.
ID:	1986   Click image for larger version
captain harlock
RC-Monster Captain
captain harlock's Avatar
11.22.2006, 05:38 PM
Impressive!!!!
I want a 1/8 buggy, too.
Nice to meet you!
bemmermazda
11.22.2006, 08:51 PM
what thickness aluminum are you using for that mount
coolhandcountry
coolhandcountry's Avatar
11.22.2006, 09:04 PM
That is nice.
It looks about 8mm or 5/16 thick for motor mount.
How the test run go?
Welcome to the forum bmmermazda.
Peace!
Country
Help support the
Rc-Monster
Buy here
Rcaddict
11.22.2006, 09:45 PM
It's 8mm aluminum.
The test run was incredible. I wanted the buggy strictly for racing and the 14/46 ratio was perfect. I can't imagine what this thing will do a 16 tooth pinion. After a 15-20 minute run the motor and ESC were at about 160*. The ESC was very smooth. I had a little cogging from a standstill, but I found that if I eased into the throttle the cogging wasn't a problem. Braking was very smooth too with the Mamba Max. I was a little concerned with the batteries being so far rearward, but after a little chassis tuning that car felt great.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.23.2006, 02:49 AM
Cool.... glad you like the setup. It's worked awesome for me...
I think it's a killler racer's setup. The 14/46 is a nice starting point.. that's what I was running. But if you really want to see some jaws drop, slap in a 16 or 18T pinion. :) :) It really comes to life then hee hee
That motor mount looks serious! Pretty nice...
Now we just need to get CC to fix the bit of cogging off the line and it's all good.
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.23.2006, 04:12 AM
Wow I am thoroughly impressed. That thing looks VERY good...almost factory...
giftacrylic
RC-Monster G-Maxx
giftacrylic's Avatar
11.23.2006, 09:12 AM
How hot did your MaxAmps batts get on your test run?
Rcaddict
11.23.2006, 09:42 AM
I forgot to check the battery temps. I'll run it again Friday and check that out.
tallyram
tallyram's Avatar
11.23.2006, 12:59 PM
that thing is nice! hope you're racing next sat. i can't wait to see the look on everyones faces when the race is over. i'm finally going to race my g2r, so we'll just have a brushless party! lol!!!!
  Send a message via AIM to tallyram
BitHed
11.23.2006, 10:08 PM
...i thought that if you put your throttle EPA into a negative number on your propo that it would cure, or at least improve the cogging off the line...It wont BURST off the line but its better than sitting there choking on itself...
BitHed
11.23.2006, 10:35 PM
...This MIGHT be a silly question but the in the closeup of the motor pic it looks like the ESC doesnt have a case on? You took it off? the thought had crossed my mind but the pros and cons of doing this? I was worried about getting goo in it...Thats not an issue?
rchippie
rchippie's Avatar
11.23.2006, 11:07 PM
Your buggy looks AWSOME :027: . How did you get the kyosho 46t plastic spur to fit ?. I was told it would not fit the mugen center diff.
REAL MEN RUN BRUSHLESS
Rcaddict
11.23.2006, 11:28 PM
That is the UBEC with the white heat shrink. The ESC has the green cooling fins on it.
BitHed
11.23.2006, 11:31 PM
...yeah but what about the black case on the bottom of the ESC? I cant see it...Is it on a lower level? Gone altogether?
