RC-Monster jumper
power output -
12.24.2006, 01:17 PM
would there be any device that could measure amp draw, voltage and stores it in a memory so you can check it out on your pc/ laptop?
i mean something you could put in the car?
many thank guys.:027:
12.24.2006, 02:24 PM
RC-Monster jumper
12.24.2006, 03:41 PM
sweet, thanks brian.
do you plug it on the battery then?
i dont find that info.
12.24.2006, 03:45 PM
Yeah, there is a set of Deans on it where you plug the batts into one and the ESC into the other. It measures current and voltage over time and creates a plot on your PC. You can also get other sensors like RPM and temperature to monitor those too.
Pretty sweet device really. It's definitely one of my future purchases...
RC-Monster jumper
12.24.2006, 04:06 PM
so, it handles 100 amps and goes inbetween batts and esc.
does that mean it limits your system to 100 amps?
12.24.2006, 04:22 PM
No, you can read out peaks of 150A with ease. the 100A is continues. It's a series module, so it needs to handle the power that is going thru it.
RC-Monster jumper
12.24.2006, 04:26 PM
thanks guys.
other question:
8 kilo car, suggest me a motor?
just thinking really, would be with 6s lipo.
also esc, wich you guys would pick for this task?
12.24.2006, 04:33 PM
8kg!? give it the weightwatchers program..
:p
a 1950/2230 wouls serve a good job.
depending on the speed you want to reach, a wanderer XL is capable of pushing it around too
RC-Monster jumper
12.24.2006, 04:47 PM
thanks rene!
2230 would have more torque i assume?
12.24.2006, 04:56 PM
Actually; No, the 1950 is a tad stronger and can handle slightly more power.
(on paper)
12.24.2006, 05:41 PM
Wow, over 17 lbs! :dft002: I'd definitely see where you could shed about 3-4 pounds...
RC-Monster jumper
12.25.2006, 06:39 AM
all i could think of would be lighter wheels.
but the ones on it are :043:
maybe ditch the nitro tranny and build a slipperential?!?
on 3 speed trannies, can you brake on your motor or do you need mechanical brakes?
12.25.2006, 07:23 AM
What vehicle is it?
with a 2 or 3 speed, you need the mechanical brake.
12.25.2006, 09:57 AM
Do you have pics of this car?
RC-Monster jumper
12.25.2006, 10:15 AM
i'm really just thinking about this, i'm not sure on anything.
car would be a cen gst 7.7.
