mod 1 pinions
BlackedOutREVO
mod 1 pinions - 02.03.2007, 02:14 AM
is there any other mod 1 pinions other then the rcm ones??? 25 bucks for a pinions is WAAAAY to much for me, especially since i like to buy like 10 pinions to find the best gearing:018:
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.03.2007, 02:35 AM
Century brand pinions at Tower are cheap... like $7 I think.
BlackedOutREVO
02.03.2007, 02:38 AM
THANKS!!! found them, there 7.25 if any one cares, and they have a TON of pinions to
pinolelst
02.03.2007, 02:54 AM
I type in "century pinion" at Tower search and find nothing...got a spare link for a brutha :028:
pinolelst
BlackedOutREVO
02.03.2007, 03:00 AM
there ya go "brutha" :D
http://www2.towerhobbies.com/cgi-bin...RY&S2=&S3=&S4= there twards the bottom of the page
pinolelst
02.03.2007, 03:07 AM
T'anks br'ah...hardened steel at that
pinolelst
BlackedOutREVO
02.03.2007, 03:09 AM
yeh good deal.. i will use those to figure out gearing, and then get one from rcm, and i might need less/more teeth then they offer to so idk
but for 7 bucks imo thats a good deal
glassdoctor
TEAM FUSION
02.03.2007, 01:07 PM
It's nice to be able to grab several pinions so you can work with more gearing options. In the past some have spent $100s on pinions alone.
I also have some from Mike... they aren't bad either @ $10, and i have one $25 hardened one.
The cheapies work fine with plasitc spurs.
02.03.2007, 03:53 PM
Originally Posted by glassdoctor
...and i have one $25 hardened one...
GD, have you tried that hardened one on a steel spur? If so, how does it hold up?
glassdoctor
TEAM FUSION
02.03.2007, 04:05 PM
Nope :) I don't think I want to risk a $25 gear unless I have to. Maybe sometime I'll be stuck with a steel spur so I can try it.
I would think a hardened pinion would hold up ok with the gear mesh right and less-than-insane power and usage. The gear I got from Mike is made from a nitro clutch bell so it should be good.
But after hearing about guys ruining hardened pinions I think it's best to just use plastic spurs.
02.03.2007, 05:29 PM
What tooth is it? Despite the bad stigma with using steel on steel, I still want to try it. I started a thread a while back on this and one part of Mike's response leads me to believe that if the motor is mounted VERY solidly, the combo should work. Maybe use a clamp style mount so it's closer to the chassis for less flex. I really think flex is what causes the issue. That and maybe the lack of a slipper. The only difference between Nitro and BL (torque aside) is the fact that the Nitro has the clutchbell, which is sorta like a slipper.
Maybe if you decide you don't want to use it, I could take it off your hands? No sense in letting it go to waste. :)
