How much heat from a UBEC?
jhautz
jhautz's Avatar
How much heat from a UBEC? - 03.03.2007, 04:15 PM
Just wondering if you guys think I will have a problem running a ubec inside of a closed plastic case? With just the shrink wrap on it, when I feel it after a run its just barely warm to the touch. So Im thinking that if its not getting hot now, putting it inside a closed case shouldnt be an issue.
I'm thinking it will be ok, but looking for some opinions. How much cooling/airflow does one of these need?
to make it...
or break it...
Silent...But Deadly
03.03.2007, 04:38 PM
You should have no problems at all. They are quite efficient so the heat is minimal. Will this be a sealed case? Because you could drill a few cooling holes in it.
jhautz
jhautz's Avatar
03.03.2007, 05:05 PM
Sealed case. To keep water out for winter bashing :)
to make it...
or break it...
Silent...But Deadly
03.03.2007, 05:35 PM
You should still be OK...
MetalMan
MetalMan's Avatar
03.04.2007, 12:13 AM
Yeah, you shouldn't have any problems at all. Let's say your servo draws 2amps continuously (on average). If the UBEC is 85% efficient and you're using 15v input and 6v output, that's only 2.7watts of heat it's putting out.
