Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
I need a cooler motor for my e-revo
gizzmo79
I need a cooler motor for my e-revo - 04.15.2007, 01:52 PM
Now i run with the feiago 8xl with 51/16 with 4s and thats way to hot:mad:1
How is the Neu 1515 1y/F Sensorless Brushless Motor wil this run cooler:036:
Does they have 5mm shaft, and can i use my qyark 125b with this motor?
Sorry the bad english i'm from Norway
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.15.2007, 01:57 PM
Thats very wierd...an 8XL on 4S should run ice cool.
AP Alex
AP Alex's Avatar
04.15.2007, 02:03 PM
What are the motor and esc temps?
gizzmo79
04.15.2007, 02:04 PM
whan i tried with 72/17 it was running cool, but it diddent have any speed.
gizzmo79
04.15.2007, 02:05 PM
I dont know but the quark did shutt off because the heat.
Serum
Serum's Avatar
04.15.2007, 02:24 PM
okay, it's not said that the 8XL is the problem then. perhaps you've got some binding in the drivetrain.?
gizzmo79
04.15.2007, 02:32 PM
What is binding? I cant understand the word
Serum
Serum's Avatar
04.15.2007, 02:34 PM
Binding; more resistance in the drivetrain than needed.
something must be wrong. what settings are you using on the quark?
gizzmo79
04.15.2007, 02:57 PM
i'm using the standar settings
gizzmo79
04.16.2007, 03:43 PM
My esc is the problem, i think it took a hit on a crash.
Finnster
KillaHurtz
Finnster's Avatar
04.18.2007, 01:54 PM
Did you try lowering the gearing a bit? I've used both 15/51 and 16/51 and the 15T does make a difference if you are running it hard (in grass or such.) Generally I run the 15T, and put in the 16T for short runs, runs on pavement, or for pure speed.
My motor temps would get to ~170F max, but after about 45 min. of off-road dirt driving w/ the 15T. Esc sould be under 130F generally. Grass runs always heats things up much quicker.
The Neu is an awesome motor regardless, but a new pinion may be a cheaper option for a quick fix.
