Get a Mamba Max controller with a 1950/7 Lehner motor and 4s lipos. Try not to use sub c cells, since you can aquire higher speeds with lipos. If you insist, 14 cells( of high quality) with the 1950/7 will surely take you to a mid 40s or even low 50s.
Nice to meet you!
if you still need to upgrade to 4spider diffs or so and to steel r&p you may want the hotbodies diffs, lightning ones. also need shims.
dont get the pro, as those are 4.3/1 instead of 3.3/1, i got the 4.3's and already regret it before using them. it will be slow with them in it. but i'm not going BL on this one. any questions ask us about it.:027:
ok i will look for those diffs :027: is this good http://www.rc-monster.com/proddetail...HPI_BUGGY_DIFF do they just drop straight in?
also i had a look and someone did a centre diff mod instead of the stock drivetrain.. is this a good thing to do
currently out of stock of the 1950 but i will look around.. this ent gunna be cheap :eek:
btw those links dont work but i will have a look around, i already did a bit and saw some pics etc
good good i like half the price :027:
so what motor would i be looking at... i tried to understand the motor charts but that didn't work to well...
maybe looking at li-po, but could get twice the cells in nihm for the same price :eek:
ya i know but only really have $600 max to spend atm...
i will try and get three different combo's going and see which you guys think is the best :027:
Hey Jimbob!:018: I see you're asking the right people on how to go about this.:027: I won't throw in any suggestions as these guys have much more experience than I do, but I can't wait to see what ya come up with mate.:027:
i would be woried to fit a neu in the stock tranny, there's not much space at all. i'd take the save route and get a lehner 1940 or 1950.
but then there are no 4mm bore pinion's for the 1940 in 32p.
Mike said the new LMT's he has coming have the 5mm shaft.
