Fluorescent Paints?
squirlz
Fluorescent Paints? - 08.31.2007, 11:36 AM
I am painting my CRT.5 body with fluorescents and the green is almost see through, now if i add my orange as the next color will that change the green? I almost used the whole can but it still is thin looking. Should i put some white over the green first?. I have never painted with fluorescents yet so i am not sure.
08.31.2007, 11:41 AM
It will probably tint the green, or at the very least lighten it a bit.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.31.2007, 11:42 AM
Yeah... anything but white/silver will change the color. Flourescents must be backed in white. That's why it doesn't look right even with a bunch of coats.
You really only need a couple coats... maybe 3-4 light coats... then back it with white or pactra's white flourescent covercoat, which is opaque. If you get a couple coats of the "covercoat" then you can even use dark colors after that and it won't show through.
Edit... even a single coat, backed with white works... but will show some light/white specks where it's not covered real good. The more coats of green the more solid it will be (and guaranteed to be uniform) but may lose a little of the super bright look of just a couple light coats.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
08.31.2007, 11:43 AM
Sorry about the hijack, but: Hey GD! Where've you been?
squirlz
08.31.2007, 12:00 PM
Thats what i was thinking. I will pick up some white and coat it before i move on to the next color.
Thanx
Dafni
Dafni's Avatar
08.31.2007, 02:03 PM
Glassdoctor is right. Think of the fluorescent paints as semi-transparent paints.
