upgraded to VXL Tranny internals in FLM Rusto
snellemin
2 KiloWatt RACER
snellemin's Avatar
upgraded to VXL Tranny internals in FLM Rusto - 10.10.2007, 01:26 AM
I upgraded the tranny gears to all steel (VXL) and used Avid Revolution bearings. Did some nice smooth speed runs and its ready for Sunday's TNT Dragrace. It's a bit noisier then with the plastic diff in there. I packed the diff with Vaseline instead of grease this time. Going to see how it works out over time.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
10.10.2007, 07:36 AM
While you had it appart you should have out a xl5 slipper on it. Love the flm tranny case, very nice!
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.10.2007, 08:26 AM
Thanks!
It's alot easier to find the old style spur gears around my area. And for dragracing I have less rotating mass on the spur, since I run it in the locked mode with this adapter.
10.10.2007, 09:51 AM
Thanks!
Ok, makes sense. If you are not going to use the slipper, then there is no point having the extra weight.
