CRT Brusless converison
enzo78
CRT Brusless converison - 10.14.2008, 11:28 PM
Hey guys, i completed my brusless CRT last week. I am using the mamba max 1/8 scale ESC, 13t pinion, Hyperion 4s 5000mah. It seems to me that the truggy is under powered. I am new to 1/8 brushless. I am using an Align 1700kv brusless motor. Am I doing something wrong here? Do I need something more powerfull?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.14.2008, 11:38 PM
Nice looking conversion, and welcome to RCM!
If it seems slow to you that's because it is. The Align motor (1700kV) and a 4s LiPo pack (~15V) only give you ~25000 max. RpM to play with. How are the temps after a run? You could try a larger pinion (say 15T) if nothing is getting very hot. Otherwise a new motor somewhere in the 2200-2500kV range would work, or moving up to a higher voltage pack (5s or 6s). The Align will handle up to 6s as will the ESC. The higher voltage option would be optimal since it will be more efficient. For a 6s pack a motor in the range of 1400-1600kV would be desired. I'm basing this on max. motor speed of 35000 RpM, which is similar to a nitro engine.
What's_nitro?
10.14.2008, 11:44 PM
Also, check out this page built by another member here- BrianG. It is an invaluable tool for all of us.
http://www.scriptasylum.com/rc_speed/index.html
skellyo
skellyo's Avatar
10.15.2008, 07:42 AM
Your gearing is kind of low for trying to get any speed out of a 1700kv motor. I run that same gearing on a Neu 1515/1Y (2200kv) and only get 36mph out of it on 4S. The only concern I would have is if that Align motor has enough power to adequately push a truggy in the high 30mph range. My guess is no.
What's_nitro?
10.15.2008, 07:20 PM
It can handle up to 1600 watts. I think that's enough (?).
skellyo
skellyo's Avatar
10.15.2008, 07:27 PM
Should be. I don't have any experience with them myself. I'm just skeptical since just about no one uses the Align motors in BL conversions. If they were that good, you'd see more of them.
What's_nitro?
10.15.2008, 08:04 PM
I currently have one in my Rustler on 4s and it flies. Not sure how it would fare in a larger vehicle.
enzo78
10.15.2008, 08:36 PM
I have a friend who wants to sell me a feigao 7xl 2382 brushless. Would this motor be much beter?
skellyo
skellyo's Avatar
10.15.2008, 09:27 PM
No. You'll end up with heat issues with the 7xl.
If you don't want to spend as much as a Neu costs, the Medusa that MetalMan recommended would do a great job in the CRT.
skellyo
skellyo's Avatar
10.15.2008, 09:25 PM
A rustler isn't even in the ballpark of the strain a 1/8th truggy will put on a motor. It's pretty much double the weight and at least double the inertial load on the motor going to a truggy from a rustler.
enzo78
10.15.2008, 07:33 PM
what motor would you suggest to get the most power? I am looking to stick with the 4s battery.
skellyo
skellyo's Avatar
10.15.2008, 07:41 PM
A Neu 1515/1Y is what I would recommend.
MetalMan
MetalMan's Avatar
10.15.2008, 07:44 PM
You could temporarily throw in an 18t pinion to get decent speeds out of it, and preorder a Medusa 36-70-2000 motor.
enzo78
10.15.2008, 07:48 PM
I appreciate the advise guys. Just so eveyone is aware, i am going to be running the truggy on the track. So should I be looking at more top speed or better acceleration?
MetalMan
MetalMan's Avatar
10.15.2008, 08:00 PM
How big is the track? You'll want to gear your truck so that you can hold full throttle for at least a few seconds each lap (too little full throttle means it has too much top end), but you don't want to be holding full throttle for the whole length of the straight. In my experience approximately 40mph is a good starting point.
