9L in rustler
Rcbros
Rcbros's Avatar
9L in rustler - 03.27.2005, 04:07 AM
Hey guys my e-maxx is MIA till I get some Ilder gears. So would it be possible to put the 9L in the rusty?
What performance should I expect out of it?
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2005, 10:11 AM
It is a little heavy and large for the rustler. Not to mention a little slow. With enough cells, you could strip the tranny in the rustler while you are waiting for your e-maxx tranny parts!
Rcbros
Rcbros's Avatar
03.27.2005, 02:07 PM
Alright i'll just clean the e-maxx and wait i guess :P
HotnCold
HotnCold's Avatar
04.02.2005, 10:55 AM
If you do the rusty - volt it to the moon and take some vid - would be cool to see....:)
Hows that "Hope and Change" working out for Ya???
RC-Monster Mike
Site Owner
04.02.2005, 11:21 AM
Yep, it would be a site to see.....until the transmission explodes (shouldn't take long)!
Rcbros
Rcbros's Avatar
04.02.2005, 12:44 PM
Yea I don't like the trany exploding part.
A bunch of friends are getting together today. should have 7 trucks we'll have some great videos up later
HotnCold
HotnCold's Avatar
04.02.2005, 01:29 PM
Tie a couple of monster trucks together - Have a pull contest - That would be wild -
kulangflow
Never Fast Enough
kulangflow's Avatar
07.24.2005, 04:48 AM
I just came across this thread through a search.
I made a quick vid clip some time ago with a 9918/9L in my Rusty .. The stock idler was gone soon after this clip was taken.
It shows my E-maxx for a bit, then the Rusty for a bit.
Enjoy .... :-)
Video
So, if the 9L isn't a good idea for the Rusty, what would be a better motor to run with my 9918 controller?
Thanks!
Brian
MetalMan
MetalMan's Avatar
07.24.2005, 09:33 AM
I used to do speed runs with an 8L in my Rustler on 12cells. It did go fast, but because of the 5mm shaft I wasn't really able to gear it properly.
Brian - you can run an 8S, on 7-8 cells it will glow.
kulangflow
Never Fast Enough
kulangflow's Avatar
07.24.2005, 12:09 PM
I'm actually using 32p gearing on it right now. I have spurs from 60,66,70,72 and 5mm pinions of 12T, 16T, and 22T.
So far I've only tried 16/60 and it had insane power until a concrete curb jumped out in front of it! (broken: front a-arm, rear slider, and tranny casing where the right rear a-arm attaches.)
Until I pick up the 8s, what do you think would be a good spur/pinion combo for the 9L in my Rusty? Actually, what would be a good gear combo for the 8s while I'm at it? Should I stick with the 32P, or go back to 48p? (I need to figure out if I need to order more gear-sets when I order the 8s.)
Thanks again for your help!
Brian
RC-Monster Mike
Site Owner
07.26.2005, 08:23 PM
The 32 pitch pinions/spurs are much tougher than the 48 pitch, so I say keep this mod in place. I would stick with the 16/60 for the 9L, but the 8s would be better off with the 12 tooth pinion.
kulangflow
Never Fast Enough
kulangflow's Avatar
07.27.2005, 12:30 AM
Right on. Thanks for your help, Mike!
I've had a ton of fun with this 9L in there. I actually geared it down to 12/60 just to try it out, and I've varied cell counts between 6,7,12,13, and 14 to see the difference. It's pretty amazing what this thing will do.
So, what will the difference be with the 8s? Will I end up with a higher top end or more starting torque? Will it just run cooler and more effecient but have similar performance? I'm trying to figure out if I should keep what I have or justify getting the 8s.
many thanks again!
Brian
RC-Monster Mike
Site Owner
07.27.2005, 06:28 AM
If you have found the performance that makes you happy, stick with it. The 8s is a faster motor, with less torque. With the proper gearing, the 8s can be faster on the low cell counts(well, quicker at least). The 8s also weighs quite a bit less than the 9L, and won't hang out in harms way off the tranny.
kulangflow
Never Fast Enough
kulangflow's Avatar
07.27.2005, 12:48 PM
Thanks again for your fantastic customer service!
I think I'm gonna have to give the 8s a shot. It sounds like it'll help me save a lot of weight with the smaller motor and less cells on board.
Gooooood stuff!
