Clodbuster Stick Crawler Build
Shane_744
Arrow Clodbuster Stick Crawler Build - 02.03.2008, 04:43 PM
Here is my clod stick. It's been built for about 2 months now. Figure I would put here.
I devised some homemade links, all- thread wrapped in carbon fiber tube then aluminum tube over that with some plastic ends. Chassis started off with 1/2" aluminum tube from hardware store and some furniture screw things. Jammed those into the 17" long tube. 1/2" bolt connects to TCS heim joint . I got some other goodies from TCS as well. Got the idea for the mounting shocks, well hose clamp, from Xerox Project (RCCrawler Board). L-brackets from hardware store.I know the stick has been done before but this was my first build.
Integy Aluminum Spools in both clod axles.
Imex K-Rocks cut up on Maximizer beadlocks. Took me forever to first cut then grind off the tread. They will need weight. mgConsiderably light.
Moabs on Aluminum Beadlocks (Don't know the brand but these things have some weight to them)
Aluminum Knuckles (Don't know the brand)
Two different rate springs on shocks and plastic limiters on shafts.
Integy 55t brushed motors paired with 8t pinions in the gearboxes.
Airtronics 94361 servos (rear locked now, also have punkrc 4ws board)
Stock Traxxas TC3 Radio Gear
Novak Super Duty ESC
Four AA's battery pack on rear axle for servos
Rubicon Jeep body.
"Anyone interested in grabbin' a couple of burgers and hittin' the cemetery?" Royal Tenenbaum
jnev
jnev's Avatar
02.03.2008, 06:07 PM
My only suggestion is to get some higher quality batteries, but other than that, it looks great. Nice job!!
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
02.04.2008, 10:50 AM
wow, awesome job for a first build!
Eflite Blade 400 heli on 3s
