LSP Conversion...
LSP Conversion... - 01.28.2008, 04:14 PM
coming soon! proposed setup is
Mega aCn 22/30/2F
Quark 80
Flightpower 5s 25c Lipo
Gearing: 15/50
here is the data:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 15
Total Voltage: 21
Motor KV: 1770
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 3.33 : 1
Total Ratio: 14.33333 : 1
Tire Circumference (inches): 17.91 inches (454.84mm)
Total Motor Speed: 37170 RPM
Vehicle Speed: 43.98 MPH (70.64km/h)
Effective Speed Rate: 2.09mph/V (3.36kmh/V)
Effective KV Value: 1770
Motor Torque: 0.28 ft-lbs
Final Torque: 3.99 ft-lbs
what do you guys think?
lutach
lutach's Avatar
01.28.2008, 05:27 PM
That will be a nice conversion. The Mega is a nice motor. You can also use lower capacity packs like the 2200 or 2500mAh.
jhautz
jhautz's Avatar
01.28.2008, 05:35 PM
I think it sounds good. I havent tried a Mega motor yet so I'm interested to hear how it goes. I am wondering if the Quark 80 is enough for a truggy though. I have been running one in a 1/8 buggy on 5s with a Neu 1512/2.5d for a while and had no issues at all, but it seems that a truggy would be a little heavier. It just might be OK, but my first instinct is that its a little small and I would look for something a little bigger.
Cant wait to see the build photos.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
01.28.2008, 05:42 PM
I forgot to attach a little video I made:
Takedown
WARNING: May become violent.
Takedown's Avatar
01.28.2008, 08:45 PM
Lutach= That Is crazy powerful! I was worried about you using a Shulze ESC since they catch fire until i heard you mention something about it and I laughed. Good luck and happy driving with your setup!
lutach
lutach's Avatar
01.28.2008, 09:19 PM
It's fine with the Mega . The system runs nice and cool. I might be getting the longer ones from Mega. I'm just curious what they can actually do.
Takedown
Takedown's Avatar
01.28.2008, 09:21 PM
Sounds really interesting! Do you think mega is up to par with lehner, hacker and neu?
lutach
lutach's Avatar
01.28.2008, 09:23 PM
I have ran all of te ones mentioned and the Mega is up there with them. I might have a surprise coming in a few weeks though that will sure be added to that class.
01.28.2008, 10:13 PM
You are such a tease Lutach! If you mean a motor, just make sure you have a 12s capable esc with proportional brakes to offer with it! And make sure it is under 150 bucks for the motor/esc!
If you could do that you would be the man!
lutach
lutach's Avatar
01.28.2008, 10:15 PM
Sorry linc. I will say more when it's here though.
01.28.2008, 10:19 PM
Sweet, I can't wait!
01.29.2008, 12:00 AM
nice setup lutach. is there a different mega you'd recommend? what mAh are the batts and what runtime do you get with them? when you said, "the pinion and spur are outta whack," you weren't kidding. it sounds like me stepping on a bag of potato chips.
01.29.2008, 12:05 AM
hows this lipo look?
http://www3.towerhobbies.com/cgi-bin...?&I=LXRVZ9&P=7
lutach
lutach's Avatar
01.29.2008, 09:00 AM
I only use the ACn22/30/2, beacause I got a good deal on it. I'm planning on getting a ACn22/50/1, but the ACn22/45/1E will also be good. Those lipos are 2200mAh and I got 23 minutes already out of them. That truck is tough, I ran it in a large parking lot at a park and lost signal. It went straight into a curb. The Flight Power is good, but ask Mike if he can get the Polyquest XQ with a 30C discharge or the Flight Power EVO30.
01.29.2008, 11:11 AM
what about this
http://www.hobbycity.com/hobbycity/s...idProduct=6236
