slipperential availablility
strodedawg
slipperential availablility - 02.24.2008, 05:57 PM
hey when is the 1/8th slipperential available? what spur will come stock? will it need new dogbones / center cvds? this is the last piece i need to finish the conversion.
thaks
jim
let's build something sick!
david lamontagn
02.24.2008, 10:47 PM
Did Like Me And Do Your Own One, With Metal Saw, Dremel And Press Drill!!!!
02.24.2008, 10:50 PM
Hey David, got pics of yours?
I want to see what you made!
strodedawg
02.26.2008, 08:56 AM
i modded a dominator slipper to fit, and i like handling ,but the combo of slipper and diff are there just for another option to try. so i would get one just for options.
mike,
can you give me some insight on the questions above
thanks
david lamontagn
02.26.2008, 10:14 AM
Yes James, as soon as my friend will finish the spur gear adaptor for the center direct drive unit and that the holes for the bearing in my mount will be did, i'll post somes pics, promise
Yesterday, i've de-anodise the chassis for a rough, factory look.
Today, i'll go at the machine shop to a little milling job on the mount.
I'll have a 46T spur on the center direct drive unit, 22T drive gear, 40T revo slipper gear and a 18T pinion on the motor.
I estimate a top speed of about 42m/h with my Neu 1515, 1Y and FlightPower 4s, 5000mAh.
I'll keep you informe of my project
Bye!
David
