CRT.5 wheels and tyres.
Sammus
Sammus's Avatar
CRT.5 wheels and tyres. - 02.26.2008, 05:11 AM
Howdy, I've got an ext crt.5 chassis in the mail and have been shopping for wheels/tyres.
I've noticed a lot of you use traxxas nitro rears all round. Ive got some of them, and tried them out. First I found that the bore on the traxxas wheels is a fair bit bigger than the crt.5 which I'm not really fond of, and the rears from my nitro evader st (same as XX-T rears) seem to be a much better fit around the axle, and also give it a slightly wider stance - mounting the wheels straight onto the pin.
When I mount 2.2 truck tyres on it they look funny - like theyre too tall and thin for this little car, so I'm pretty keen to get some of traxxas 2.8s or proline 30 series on it (slightly smaller OD but wider) which I think should look pretty trick. Hopefully they bring out some different tyres soon - at least some M2 compound so they last a bit longer. I've already said that the traxxas bore seems a little too big, so can someone tell me if the XXX-T wheels are the same mounting specs as the XX-T? Then I could go the 30 series route.
And lastly :P is there anywhere to buy the pro line 30 series mounts separately? I'm guessing I'll only need 2 sets of the rear mounts, and everyone seems to sell a set of 4 - the fronts they give you would be useless to me...
Cheers... sorry 'bout the long post, but for some reason I thought my train of thought was important if you see anything wrong in there let me know so I can think some more! :P
