Al. Radio Case.. Cheap!!
entjoles
Al. Radio Case.. Cheap!! - 05.12.2008, 09:35 PM
i found this from a different site but had to get one and do a write up on it
i got this al. case at Menards,in the hardware section, im sure other hardware stores will have them as well, it cost like $20...and it fit alot of stuff, it is wired up underneath the foam so i can plug my charger in directly
best of all its orginized
pic of pull apart foam 1/2x1/2xabout4" deep
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.12.2008, 10:26 PM
That is pretty neat. It definitely beats my bucket.
JThiessen
JThiessen's Avatar
05.12.2008, 10:41 PM
Very nice. You have the same set up I have - just a nicer case. I brought home a Dewalt screwdriver case to do the same thing with.
Does your charger get hot running with all the foam packed around it?
entjoles
05.12.2008, 10:45 PM
dont know yet, but when i charge my batterys at room temp. the fan on the power supply only kicks on the last 15min. of a one hour charge, ill post it up if i run into problems
MetalMan
MetalMan's Avatar
05.12.2008, 10:58 PM
Those generic cases are awesome! I got one from the LHS I work at for like $10 that's about half that size - it's PERFECT for my Nomadio React radio. Looks like yours will be very handy .
JThiessen
JThiessen's Avatar
05.12.2008, 11:04 PM
Do you by chance know how to set up the 989 to charge two NiCd's? My serial adaptor is set up right, it just seems that I cant get the settings right to make it charge them together.
entjoles
05.12.2008, 11:23 PM
i dont know on the charger , i have only charged my lipos , sorry
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.12.2008, 11:27 PM
You can also find these cases at Home Depot, etc.. and Harbor Freight too. They don't always have the nice full foam though.
I have a couple of them... one for my radio and one I use for my laptop. :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
