question about Futaba FASST
azjc
question about Futaba FASST -
05.07.2008, 10:02 PM
the reciever has a much shorter antennea, what has everybody done to set it up...do you still use a tube? Is one needed?
azjc
2
BlackedOutREVO
05.07.2008, 10:17 PM
It isnt needed, but since its got the coaxial antenna it cant be bent to a right angle, so make sure its not bunched up all crazy, keep it curved
BlackedOutREVO
3
azjc
05.07.2008, 11:08 PM
Originally Posted by
BlackedOutREVO
is it better to not use a tube than? Would it matter if you strapped it to the truck?
azjc
4
Blunten
05.07.2008, 11:09 PM
I use the tube in mine and just tape it laying down on the chassis.
Blunten
5
Sammus
05.08.2008, 08:31 AM
I use a short tube, I cut a slit up the tube at the bottom so the antenna can exit a little early and I can still jam the tube in its holder hard.
Sammus
Find all posts by Sammus
6
BlackedOutREVO
05.08.2008, 06:04 PM
Heres mine, the pic wasnt taken to see the antenna, so is not the best, but you can see how mine is, the tube is a few in long...
Run a tube IMO, just keep the wires with a curve, dont cramp them together
06:09 PM
BlackedOutREVO
7
Cartwheels
05.16.2008, 02:10 AM
you can heat up the tube where you want it to curve then when it cools it will stay that way.
Cartwheels
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
