origional MM that works compared to new "fixed" one
auto2
origional MM that works compared to new "fixed" one - 07.07.2008, 08:37 PM
just curious, i have one of the GOOD origional mmm's. any reason or suggestion to trade in a working one for the updated'fixed version?
i still keep running battery after battery just waiting for a shutdown.lol
VintageMA
VintageMA's Avatar
07.07.2008, 09:13 PM
Ya know (knock-wood) I have 2 of the original batch of the MMM that both easily have over 5 hours each on them at this point on 6S running with the internal BEC and no fan problems. I keep waiting for them have a problem, but to be honest they perform so smoothly - temps haven't gotten above 120* even pushing ~1500 watts through them - internal resistance is really low.
I wonder if Patrick (are you out there?) will be offering a trade in for the original batch to the 2nd round ones. Not sure I would even pick-up on it unless I get reports that the 2nd batch are that much better.
Still looking forward to hearing more on some of the other 5-10S spec lower amp speed controls.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Robert
07.07.2008, 09:19 PM
MM or MMM? There's some confusion here.
jhautz
jhautz's Avatar
07.07.2008, 09:32 PM
I'm sending mine all back when they have the new versions.
I just had my first MMM shut down on me. It had a good 8-10 hours of use on it. The BEC failed. It ran normal all day thru the 3 qualifiers and I shut it down and unplugged the battery as normal. About a half hour later I went to go change the battery and start prepping it for the main and it wouldn't turn on. Nothing. Just dead. If i started the fan spinning it would keep it spinning for a while as if it had a very low voltage running on it still and when I plugged a Rx pack into the receiver it actually started up and spun the motor on the bench for about 5 seconds then it quit again. I yanked the MMM and replaced it with another MMM I had all set up and sitting in the pit box just in case. (as it turns out a good decision) I am sending the dead one back and having it replaced and then when I get that back I am going to yank the other one working or not and have it replaced. I just don't trust that it will keep working. I thought I had a good one. And by comparison to what happened to others I did, but it just couldn't go the distance and I don't trust the other one to do it either.
On the brighter side... I won the B-main and bumped up and then took 3rd in the A-main for 1/8 buggy and took 1st in MT with the G2R Revo. Very good day for me. It made me forget about the dead MMM.
to make it...
or break it...
Silent...But Deadly
Edumakated
07.07.2008, 10:53 PM
JHautz:
Yours did the same thing my first one did. I probably had 6 or 7 hours of use on it and it just died after I stopped for a battery swap. Nada, nothing zilch.
The other just went up in smoke. Knocking on wood that the one I have in the car now continues to work until the new batch comes out. Castle also has my old MM too, so hopefully I will get that one back soon.
I am on my 3rd MMM. I can't afford to purchase a fourth, particularly if I don't even know if it will last. If this one fails, I am going to be out of service for a while.
auto2
07.07.2008, 11:07 PM
sorry guys. supposed to be MMM not MM LOL how do i change a title???
George16
Supermaxx
George16's Avatar
07.07.2008, 11:17 PM
Mine is still working too but I will be trading them for the V2. I think Patrick posted somewhere about the trade in after they take care of the people who had problems with their MMM first.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Pdelcast
Pdelcast's Avatar
07.08.2008, 10:05 PM
Yep -- exactly right.
Patrick del Castillo
President, Principle Engineer
