Building an FLM Electric Pede ???'s
Badgerboy1970
Building an FLM Electric Pede ???'s - 08.14.2005, 01:15 AM
Hi
I plan on buying most if not all of the FLM electric Pede parts at the end of this month and just have a couple of questions.
The first question is what is the main advantage/disadvantage of the standard vs. extended length arms? Is there any reason NOT to go with the extended arms for more stability like CVD/turnbuckle/stock drive shaft problems?
The second question is I was wondering if I should keep the stock plastic chassis braces or put a Swami wheelie bar on the rear and a New Era brace on the front.
The last question is what hardware is included with the FLM extended chassis kit and what hardware will I need to purchase seperately (which stock parts will I not be able to transfrer over if any)? I know this is a lot of questions, just want to get everything lined up so I can spend more time running and less time wrenching :D
Thanks!
