Battery,ESC,Motor Temps
MaxRevo
MaxRevo's Avatar
Battery,ESC,Motor Temps - 06.08.2008, 11:10 PM
What is everyone using to monitor there temps in the vehicle and on the charger. I have a duratrax flashpoint would that work and what would have to set it at.
dirt101
dirt101's Avatar
06.08.2008, 11:21 PM
I use the same temp. gauge and I havent had any problems. I use 77E for everything but note that the batteries will be slightly higher than what the guage says unless you are running nimhs.
TDC57
TDC57's Avatar
06.09.2008, 04:31 PM
Use any one of these for temp reading, I’ve never mounted in anything, I just bring the truck in and point the beam at what I want read, Battery, esc & motor one temp gun does it all..
http://www.impaktrc.com/advanced_sea...0e44341af7ef3f
Hope that helps??.
Have a great one..
Nothing!.. Hahahahaaa..
Robert
06.09.2008, 04:41 PM
I use the same gauge and setting also.
VintageMA
VintageMA's Avatar
06.09.2008, 04:50 PM
I think the Raytek MT4 is a really great one. All the maintenance guys here at work have them for troubleshooting HVAC issues.
Why Impakt RC is asking $75 when amazon wants $41 is beyond me though.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Jeremy1976
06.09.2008, 05:56 PM
I use the Raytek too and love it. You can get them on Ebay brand new for around 35. Suppose to be one of the better temp guns.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.09.2008, 06:09 PM
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
VintageMA
VintageMA's Avatar
06.09.2008, 08:39 PM
I actually use the FlashPoint myself, but have been checking out the Raytek for a while now.
Just checked the E setting on mine and it was set for the default 95E.
I brought up the manual and it says 77E for Anodized Aluminum.
Does that mean that all of the motor temperature readings I have been taking for batteries are pretty accurate, but the motor and ESC temps I've been reading at 95E have been lower than what the reading has been saying?
dirt101
dirt101's Avatar
06.09.2008, 08:59 PM
yes, thats exactly how it is. It really doesnt change but a couple of degrees.
VintageMA
VintageMA's Avatar
06.09.2008, 09:07 PM
Yeah - I temped my Neu at room temperature at both 77E and 95E and the temps were:
95E - 77.0*
77E - 76.4*
I might give it a try when running just to see if there is more of a discrepancy at higher temps when the motor is really pumping out some heat.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
06.10.2008, 05:25 PM
I have the flashpoint. At high temperatures the default setting is very inaccurate for aluminum. My smooth can feigao would read 90F on the can while about 150-160 right where the wires came out. I also measured the temps of my aluminum pots that contained boiling water and the outsides read about 95F. Other than that, the readings are very accurate for nonshiny surfaces.
Area 52 Ranch Raceway
T.R.C.R.
