I use the same temp. gauge and I havent had any problems. I use 77E for everything but note that the batteries will be slightly higher than what the guage says unless you are running nimhs.
I actually use the FlashPoint myself, but have been checking out the Raytek for a while now.
Just checked the E setting on mine and it was set for the default 95E.
I brought up the manual and it says 77E for Anodized Aluminum.
Does that mean that all of the motor temperature readings I have been taking for batteries are pretty accurate, but the motor and ESC temps I've been reading at 95E have been lower than what the reading has been saying?
“Everyone has a right to be stupid; some people just abuse the privilege.”
