BK controller stuck in programming mode! HELP
BLmaxx
BK controller stuck in programming mode! HELP - 08.14.2008, 10:42 PM
It was fine the day before but now when i plug the batteries it makes the first beep to program it. The red jumper is in and i check the solder on it, everything seems fine. What should i do?
Thank
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.15.2008, 12:51 AM
Hmm.. Take the jumper out and see what it does?! That is really wierd, if you cant find a bridged trace somewhere on the board. Also, you might check the jumper itself to make sure it has good contact ie. isn't loose or wobbly.
BLmaxx
08.15.2008, 01:46 PM
It does the same thing. I Checked it and it touches each other.
BLmaxx
08.17.2008, 07:45 PM
Did anyone ever have this problem???
What's_nitro?
08.18.2008, 07:17 PM
I'm sorry I can't help you out more. I do need to correct myself from my earlier post:
You would actually be looking for "broken" traces, not "bridged" traces, since it enters programming mode when the jumper is removed. I don't think it'spossible for the programming to cause this, so there must be a trace on the board somewhere that needs to be patched.
