HV 7.5 Motor, Good On 5-6s?
Takedown
WARNING: May become violent.
Takedown's Avatar
HV 7.5 Motor, Good On 5-6s? - 07.13.2008, 05:24 PM
I was wondering if the HV-Maxx 7.5 motor with 5mm shaft would be a decent motor to do a conversion in a 8th scale buggy on 5-6s lipo with the MMM set properly. I know the kv is a little high but would it outpreform the 6XL feigao motor on the same voltage seing their around the same kv? I wanted to know because novaks motors are 4-pole sensored and you'd think they would preform great in a 8th scale in sensorles mode tuned properly on 5-6s lipo. All help would be greatly appreciated.
RIP- Tammy (9/14/08)
07.13.2008, 05:32 PM
Its a 3000kv motor.... on 6s lipo thats 66,600rpms...
I wouldnt like to run it that fast for any length of time- it works best when used in spec at 4s lipo, and geared accordingly. With a lighter 1/8scale conversion you could gear taller than when using the motor in a 10lb emaxx, but I wouldnt push your luck.
Takedown
Takedown's Avatar
Ok Ill see what other people have to say.
Takedown
Takedown's Avatar
07.13.2008, 05:36 PM
I think Ill go with the Medusa 36-60 1600kv instead. Same price but alot better.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.13.2008, 05:40 PM
Good and smart choice
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Takedown
Takedown's Avatar
07.13.2008, 05:41 PM
Thanks DB. I think its the smarter idea of the two also.
