help me tweak my setup.......... -
08.19.2008, 01:59 AM
ok, so now that I have a working MMM, I need a little help. With some moderate duty running in the grass, my MAX temps were as follows:
MMM: 140
Neu: 165
battery: 123
Setup:
Muggy (12lb monster truck w/ center diff)
Neu 1515 1Y (2200kv)
MMM v2
Hyperion 6S 4800mah 20C
12T pinion
I also have an 18T pinion, but really, I want to know, are these temps ok, or am I too close to a bad place? Outside temp was about 85, and these temps were after about 15-20min running in the grass. Seems everyone else is running cooler than I am.
BTW, you guys were right, BL is INSANE!! I'm hooked!! And while I get that people want the feel of mechanical brakes, hitting the brakes on this setup is like dropping an anchor!!! And the MMM is at 60% brake!!
