where to mount the esc
toby
toby's Avatar
where to mount the esc - 11.01.2005, 07:58 PM
i was thinking liek this, and this is temporary, if i keep it there i will make something that protects it, would this work, why or why not?
rc18mt/blade cp
toby
toby's Avatar
11.01.2005, 07:59 PM
i was going to just attach it with them zip tie things as well
rc18mt/blade cp
squeeforever
squeeforever's Avatar
11.01.2005, 08:04 PM
do you have the ability to make an aluminum mount? can you get a better picture of the whole truck? maybe from the top?
toby
toby's Avatar
11.01.2005, 08:07 PM
i have a photo from the top already that i can get, the thing is, this needs to be done for thursday. so i am kind of in a hurry
rc18mt/blade cp
squeeforever
11.01.2005, 08:15 PM
how about on the opposite side of the motor on the inside of the tvp's?
toby
toby's Avatar
11.01.2005, 08:19 PM
then it is to close to the spur gear
rc18mt/blade cp
squeeforever
11.01.2005, 08:57 PM
i mounted mine to the shock tower on my maxx. not sure about the savage towers but do you have a picture of the towers?
toby
toby's Avatar
11.01.2005, 09:02 PM
rc18mt/blade cp
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
11.01.2005, 09:31 PM
I wouldn't mount it outside the tvp's, otherwise it could be hit by twigs, debris etc.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
dabid
Put it on the opposite side of the motor, and use zip ties to keep the spur from eating the wires. I've seen it done, looked just fine and worked great. If you want, you could even go with a short section of alum. angle bolted to the left chassis plate, that'd make it look a bit cleaner.
squeeforever
11.01.2005, 09:40 PM
what you could do is like dabid said, use angled aluminum and mount it on the inside of the tvp. it would protect the wires if you take the angled aluminum and cut either the bottom or the side long and the opposte to the correct length and simple bend a 90 degree angle in it. ill see if i can make something to show what i mean if you dont understand.
Gustav
Gustav's Avatar
11.01.2005, 11:02 PM
Is the 12020 warrior longer than the 9920?
I'd try to get it next to the motor there too and keep the wires away from the spur with zip ties if you have room.either that or on the shock tower if there's room.if you do have to mount it outside the TVPs then you'd need to build some protection for it or stones/projectiles from the front tyres will damage it.
