shock pistons
traxxasbasher13
shock pistons - 11.02.2008, 04:22 PM
I have been jumping my e-maxx a lot lately so I went to my LHS and got some 50wt oil. After i filled each shock my suspension seemed a lot softer! If i drill extra holes in the piston will the oil work better.I thought I saw it done somewhere. Thanks
traxxasbasher13
11.02.2008, 06:27 PM
Anybody?
JThiessen
JThiessen's Avatar
11.02.2008, 06:43 PM
Drilling holes will only decrease rebound resistance. You must have had heavier oil in the shocks before.
Are you certain you are comparing apples to apples? Ie., same springs, same spring shim set up?
traxxasbasher13
11.02.2008, 09:26 PM
Yea the shocks had 30wt in them before. It's the same every thing else also. Should I rebuild my shocks?
Andrew32
11.03.2008, 03:54 PM
sometimes the old dirty gunked up oil will feel heavier than it was. When you replaced it with the cleaner oil, it made the shocks seem softer by making it smoother.
Duster_360
11.04.2008, 01:20 PM
One other thing - one companies 30 weigh is not necessarily the same as another companies. I've seen some wide disparities between weight from one brand to another.
traxxasbasher13
11.24.2008, 03:12 PM
Ok I refilled my shocks today and now they work like a charm! I put the one hole pistons in them and new AE 50 wt oil. Heading to the dunes this weekend and i'm gonna try them out. hopefully there not to stiff!
