G3 Race setup
rc4x4nut
G3 Race setup - 01.24.2005, 02:32 PM
For the racers out there. How do you setup your suspension? Caster? Camber? Wheelbase?
Thanks
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.24.2005, 10:54 PM
There are a few options or things to consider when setting up your truck. Everyone will have there driving style and therefore some preferences. A short track will usually require more steering, so the shorter wheelbase may be the hot set-up. If there are not a lot of tight corners, go for the long wheelbase option, as it is easier to drave and will help the chassis absorb the bumps better. I typically set my camber to about -1 degrees (tires leaned slightly towards each other), while I run the lowest castor setting (more castor = less steering) I like my truck to have a lot of steering, though. If the steering feels twitchy, ad more castor. For the suspension/shocks, this may vary track to track, but you want to be able to absorb the bumps without bottoming out or upsetting the chassis. It is OK to bottom out from a big jump, so long as you don't bottom out all over the place. On a bumpy track, soften the suspension (lighter oil) to allow the suspension to act faster and absorb the bumps. I like my suspension arms to be about level to the ground on most tracks. If it is extremely bumpy, you may want to raise the suspesnion a little. On a smooth track, lower is better. Hope this helps!
rc4x4nut
01.24.2005, 11:03 PM
That helps alot. My setup right now is still the stock arms (still waiting on the G3) and proline powerstroke shocks with 30wt oil. The powerstrokes to me is a good investment. you can adjust the stiffness of the springs adjusting the tension on the helper spring.
Sylvester
Sylvester's Avatar
02.27.2005, 05:48 PM
im waiting on my g3 too. once it comes in i will poop my self than start the assembly.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
HotnCold
HotnCold's Avatar
02.27.2005, 06:59 PM
then clean yourself i hope - LOL
Hows that "Hope and Change" working out for Ya???
Sylvester
Sylvester's Avatar
02.27.2005, 07:08 PM
i might not have time to do that :( LOL
Losi 8ight e
