MMM v3 hiccup?
brushlessboy16
brushlessboy16's Avatar
MMM v3 hiccup? - 12.05.2008, 04:37 PM
Im having an odd problem with my v3 mmm, It seems to hiccup or lose signal about 75 feet from me. it doesnt entirely lose the signal- its like a blip where the throttle goes to neutral. anyone have this problem, and how do you fix it?
Setup is:
Cen Matrix truggy
V3 MMM
CC 2200
5s zippy lipo
geared for 42mph
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.05.2008, 04:42 PM
Does it do this in any direction relative to where you stand? It's probably radio related. Where is your Rx located relative to the ESC/motor/BEC(?)? It should be as far away as possible from those things to prevent glitching.
redshift
RC-Monster Square Tube
redshift's Avatar
12.05.2008, 04:49 PM
I had this happen with my Mamba Max- only mine went into full brake for a fraction of a second, but it happened at full throttle-- was kinda ugly.
brushlessboy16
12.05.2008, 05:34 PM
Im running spektrum dsm through my m8, it happens any direction- the rx is in the front of the truck, batt, motor and esc are wayy back
i dont know if it would catch interference from that
I had this happen when i was running 75mhz, it would do that....
What's_nitro?
12.05.2008, 05:40 PM
In that case, I doubt it is interference if you're using DSM.
12.05.2008, 05:50 PM
Does it happen a certain point on your street - 2.4 is not immune to interference - it could be a neighbours network router or telephone
brushlessboy16
12.05.2008, 06:10 PM
Its not its kind of random, happens sumtimes and then doesnt the next
What's_nitro?
12.05.2008, 06:16 PM
Would a faulty switch do this?
Edumakated
12.05.2008, 06:25 PM
DSM can lose signal. I have a DX3r and it loses signal right in front of one of my neighbors house sometime. I also had a problem in a particular parking lot. It is getting interference from somewhere...
shizzon
shizzon's Avatar
I have noticed this with my E-revo, not sure what the cause is. it pretty much does what you have just said....ill be going and the truck will just loose the signal for a second or less and then it will just work again. I didnt notice it happening at any particular distance but 75 feet or so seemed to be when it happened the most.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
riverat1540
riverat1540's Avatar
12.05.2008, 06:54 PM
also had this problem with my 1oth scale mm and i am also running spectrum
its a glitch from the radio
always seems to happen in the same spot try moving your electronics around in different comboes if u can. thats what worked for me
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Happywing
12.05.2008, 09:24 PM
I was running a receiver pack (with regulator) and decided to try the MMM BEC. When I did, I started having the exact same problem. I went back to the Rx pack and all is good.
E-fanatic
Brushless only!
E-fanatic's Avatar
12.05.2008, 10:22 PM
I had issues with my spektrum like this, It would lose signal at about 75ft. I switched to the futaba fasst 2.4 3pm and now have no issues even at 1000ft away! I will never go back to spectrum!
e-mike
e-mike's Avatar
12.05.2008, 10:36 PM
my firend to had this issue with spektrum...he switch to fasst and everything run good now
D8t on juice!!
E-fanatic
Brushless only!
E-fanatic's Avatar
12.05.2008, 10:38 PM
Yeah after buying 4 spectrum systems and only having one that would give me 400ft(max) without issues and my neighbor,brother and brotherinlaw all have spectrum radios and have horrible range issues! I was told that the dsm2 systems have fixed the issue but my wallet hurts to bad to try again!
