Dimension Engineering Sport BEC
George16
Supermaxx
George16's Avatar
Dimension Engineering Sport BEC - 01.26.2009, 08:58 PM
Is anybody using this BEC with their Sidewinder or MM ESC? Did you have to cut the red wire from the ESC? I just installed this BEC on my sidewinder without removing/cutting the red wire. Is this good or bad.
http://www.rc-monster.com/proddetail...portbec&cat=18
Thanks.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.26.2009, 09:37 PM
That BEC has a throttle cable pass-through, which just allows the negative and signal wires through. So, it automatically disconnects the red wire without having to mod the throttle cable.
George16
Supermaxx
George16's Avatar
01.26.2009, 10:53 PM
Thanks Brian.
Revo with OS .18TZ
TDC57
TDC57's Avatar
01.27.2009, 03:21 AM
For what it worth (right or wrong) I pulled my red wire on my MM.. But BrainG is the GOD of knowledge so I would go with what he said.. Maybe hahhahaaa..
Have a great one Sir..
Nothing!.. Hahahahaaa..
01.27.2009, 10:48 AM
God of knowledge... yeah, right.
I generally do the same (pull the red wire) in any BEC just to be consistent, but it's much easier to just use the pass-through feature. In the case of the SportBEC, you can actually follow the red wire PCB trace and you'll see it does not go anywehere on the BEC.
