Can I Charge Li-ION With my BC6?
rawfuls
roofles.
rawfuls's Avatar
Can I Charge Li-ION With my BC6? - 03.22.2009, 01:17 PM
Well, my dad has camcorder batteries, and the original charger doesn't work..
So I was wondering if anyone knew if I could somehow "trick" the charger into charging it.
The battery is 7.2V.
One is 10.8 Wh
And the other is 1350mAh.
Any clue anyone?
03.22.2009, 02:32 PM
If it's a 7.2v pack, those are 3.6v nominal cells, which is obviously a little lower than the typical lipo 3.7v.
There are a couple ways you could charge that, depending on your charger's capabilities:
1: Set the CC/CV threshold to a lower value, something like 4.0 or 4.1v/cell. The charger must support a settable threshold, read the manual to see if it does. Or, there may be a "storage charge" setting where this value is settable.
2: Charge it on a 2s lipo profile but watch the voltage. When it gets to 4.0-4.1v/cell, manually lower the charge rate to keep it no higher than that. Your charger must support on-the-fly current adjustments; most don't. FYI: I don't mean stop the charge, set the current lower, restart, etc; I mean adjust the current during charge.
rawfuls
roofles.
rawfuls's Avatar
03.22.2009, 04:58 PM
Huh.
I just got home, and remembered that I was able to set the voltage, in the program selections.
Well, turning it on, I switch to programming, and it sure does let me charge Li-IO (Which I assume is Ion)
Got anything on this subject?
I'm not sure if it lets me change the voltage on storage.
03.22.2009, 06:06 PM
Well, if it has a special Li-Ion setting, use that...
rawfuls
roofles.
rawfuls's Avatar
03.22.2009, 06:08 PM
Lol, I just noticed it, sorry.
You can delete this thread if you wish.
