drift practice vid - xray t2
DickyT
drift practice vid - xray t2 - 04.23.2009, 09:26 AM
http://www.youtube.com/watch?v=3s3ZyoaECmk
A little practice last night for this saturday's competition.
04.23.2009, 09:48 AM
Nice! I have never really watched drifting before...seems to require a ton of precise control
DickyT
04.23.2009, 10:12 AM
Thanks! there certainly is alot of skill and control required. A month ago there is no way I could have got the car through those tight areas I made,now I find it pretty easy.
Andrew32
04.23.2009, 11:49 AM
SICK! jsut SICK. I have to heavy of a finger to do that...
js058515
Thank You Brushless Gods!
js058515's Avatar
04.23.2009, 01:28 PM
That was nice to watch......Can you post your exact set-up? I have been thinking of dabbling in an on road drift car but am not sure where to start.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
bigboi146
Multi Tasking
bigboi146's Avatar
04.23.2009, 01:34 PM
Your very good at that... I don't think I could get that close to the wall without breaking parts... Good job!
What tires are you using?
04.23.2009, 01:45 PM
Nice driving. I can do that too, but only if the cones are about 50 feet apart.
Do you use the D-box or similar? Or is it all you?
DickyT
Thanks all!
I am running an xray t2, novak slyder esc with 7.5 slyder motor and a 6.00 final drive ratio. loose ball diff front, spooled rear, 1 degree toe out front, 2 degrees toe in rear, -1.5 degree camber all the way around. The front shocks have 25 wt oil, 14lb srpings, 4 hole pistons and are positioned on the middle tower hole. The rear shocks have 25wt oil, 17lb springs, 4 hole pistons and are on the second hole form the outside on the tower. The tires are hpi t-drift.
