2650 on 5s hotbodies lightning street 1/7 (hehehe)
cheesecake
2650 on 5s hotbodies lightning street 1/7 (hehehe) - 04.28.2009, 02:11 PM
Well i pulled the esc out of my buggy because i wanted to get a testrun in on my 1/7th scale lightning street.
castle neu 2650
mamba monster
18/44
13/43 diffs
so i take it out and get some good passes and its hauling i would roll into it till full throttle and it was flying down the street. it would start to skate around as i hit full throttle... well i got into it to hard and the front end unloaded and so did my tire it ripped itself into pieces.
so i went to the tire bag and grabbed a bald set of buggy tires i had and threw them on well they fared a little better but they're now trash
so all in all it was fun and hopefully ill have some video next time.
btw motor temps never got over 110 esc i got the fan to turn on temped at 155 and the battery was 110 that was after a good 10 minutes of running
04.28.2009, 02:17 PM
always have video rolling, sheesh
What mount did you use for the motor? I have a LS too, and want to convert it!
cheesecake
04.28.2009, 02:18 PM
i used the caster racing mount out of the fusion because i had one laying around i used the whole caster diff mount and diff also
cheesecake
04.28.2009, 02:21 PM
dont worry i will next time i left the camera at my house
cheesecake
04.28.2009, 02:27 PM
Also The batteries were 5s 5000mah 15c trueRc Packs hopefully i can radar it next time also
cheesecake
04.28.2009, 03:08 PM
Any reccomendations for tires that wont explode and a reccomended diff fluid so the front end doesnt unload
04.28.2009, 03:25 PM
rchippie had a line on some belted tires. Maybe contact him? I plan on getting some for my Ultra GTP since I trashed the stock tires.
Edit: Found what I was referring to: http://www.rc-monster.com/forum/showthread.php?t=15905
04.28.2009, 03:28 PM
100k for the center diff sounds about right. I plan to leave the 2 speed in mine, and aim for 90+ mph sppeds, so some decent tire info would be good too. BSR make caps, which supposedly are very good. Lutach said his relative in brasil makes tires and was going to make some decent belted tires for rc...
Hard shore foams would hold up better, but I doubt that they would wear well.
Last edited by lincpimp; 04.28.2009 at 03:29 PM. Reason: I live my life a 1/4 mile at a time.
04.28.2009, 03:29 PM
Just curious, what would the purpose of a CD serve in an on-road car? I would think a solid center drive would be preferable.
cheesecake
04.28.2009, 03:40 PM
i just ran it this way because i had the diff and a regular pinion im going to order up the rcmonster 2speed parts and we can see what happens after that.
04.28.2009, 03:46 PM
I don't know about linc, but the one time I got into second gear, the torque broke all 4 tires loose and lost control until I let off the throttle. Wasn't fun for me. Great for speed runs but not so much parking lot/street bashing.
[OFFTOPIC]
Does anyone make a "generic" locking center hub for the typical 46T CD spurs? I know a select few vehicles have that as an option, but was thinking more general purpose. This could either be a center diff insert or a different unit altogether. The GTP has a single speed option, which I'm using, but it's made for 51T spurs, which are too big for normal buggies/truggies.
[/OFFTOPIC]
04.28.2009, 04:00 PM
Yes the CEN locker works
cheesecake
04.28.2009, 04:01 PM
ofna has on in the oval car kit but i cant find the part number
cheesecake
04.28.2009, 04:06 PM
never mind its 51 tooth like you said
