Esc heating up ?
Jason
Exclamation Esc heating up ? - 05.31.2009, 06:02 PM
I played today with my crt.5 and all goes fine now back from playing again and the esc heating up for nothing ... the motor is cool and the batteries also but the esc can goes up to 200f + into few minutes maybe less...
Jason
05.31.2009, 06:37 PM
back from trying a external bec and the same
brushlessboy16
brushlessboy16's Avatar
05.31.2009, 06:41 PM
we need more information dude. this doesnt tell us squat. for all we know you could be running a hw 18a, neu 1527 and AA's
Jason
05.31.2009, 06:44 PM
jammin crt.5 1/12 truggy
1/10 mamba max esc
feigao 8xl
3s lipo 5000mah 25c
17/46 gearing
top speed around 35mph ...
all worked perfectly fews days ago and sudently the esc heating up for nothing ...
e-mike
e-mike's Avatar
05.31.2009, 06:46 PM
jespere que ta pas les gros tire que ta montré a carl...si oui pose pas de question au sujet des temperature....
D8t on juice!!
Jason
05.31.2009, 06:47 PM
heh oui j'ai c gros tires la j'ai rouler pendant 2 jours pis aucun probleme de température mais la je comprend pas... p-t le moteur qui est foutu ?
brushlessboy16
05.31.2009, 06:50 PM
Oh the joys of canadians eh.
Can someone fill us in?
Were in Uh'mericah :)
e-mike
e-mike's Avatar
05.31.2009, 06:53 PM
loll yes could it be your motor...FEIGAO=CRAP...i sold you a neu few month ago yer rendu ou ste moteur la?????..enleve les tires cer dla boullshit
sorry brushlessboy16 but jason had some really big tire un is crt and and cheap motor=the present result
D8t on juice!!
Jason
05.31.2009, 06:57 PM
le Neu est dans mon kyosho st-r 1/8 truggy
e-mike
e-mike's Avatar
05.31.2009, 07:01 PM
ok ..good...bon first...baisse ton timing a lowest...punch at 60% combien de kv ton moteur..... ya tu dejas overeated?
do you have the latest soft???
D8t on juice!!
e-mike
e-mike's Avatar
05.31.2009, 07:05 PM
anyway...your motor draw to much amps for the cell capacity....and the esc is not able to drive the motor ..well i think...
D8t on juice!!
Jason
05.31.2009, 07:09 PM
le timing est low , start power low , punch control 70% j'ai essayer la version 1.20 pis 1.21 du firmware ... j'ai jouer avec depuis je l'ai avec c gros tires la pis rien chauffait c jusque que cette apres midi ca commencer a chauffer
e-mike
e-mike's Avatar
05.31.2009, 07:15 PM
combien de fareineith i pogne????what temp exactly...if you can hold your finger on it...its ok next run check with a temps gun
D8t on juice!!
Jason
05.31.2009, 07:28 PM
jvient dessayer avec les tires on-road qui a venu avec pis le esc monte a 200f + aussi :)
chavait que sté pas a cause des gros tires ;)
pis le moteur rien a dire ca chauffe pas ... juste le esc ...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.31.2009, 07:37 PM
I resent the comment...
What do you expect, they are French!
