Carbon Fiber GTP
phatmonk
RC carbon junkie
phatmonk's Avatar
Carbon Fiber GTP - 05.03.2009, 10:51 AM
So I have finished my GTP SSG Graphite Chassis and ESC/Rear chassis brace.I decided not to use the side mudguards.I also widened the chassis on the motor side 6mm.This thing is a rocket,I did some speed runs and with the foam tires its alot easier to control at high speed.It has a Neu 1515.5y/s with mild settings on the MMM and 3s lipo..The fan only came on twice in 70f weather.
ID:	6924   Click image for larger version
ID:	6925   Click image for larger version
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
05.03.2009, 11:17 AM
Purrrrrrty! I'd venture into some better lipos though, maybe some TP 40c packs?
Gtp
transtalon
Gtp - 05.03.2009, 11:31 AM
How is the foam tires on asphalt surface? Does it last long? I have a 1/8 buggy that I put a 1515 1.5D and 5S with a 20/43 gear. The only tires that lasted a long time was the road rage tires. Also can you tell me what kind of tires so I can try one out. I mostly ran in the parking lot. Thanks.
nitrostarter
nitrostarter's Avatar
05.03.2009, 11:59 AM
You may want to give these tires a try:
http://www.losi.com/Search/Default.a...Term=450_Rally
They should last a bit longer than the foams and still provide great traction.
I know they are good for 103mph on a GTP....
http://www.youtube.com/watch?v=cjsuJTVPbP0
N. Rustler conversion
snellemin
2 KiloWatt RACER
snellemin's Avatar
05.03.2009, 03:53 PM
That looks like a land rocket. Nice work on the carbon fiber.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
SidewaysLS4
05.04.2009, 09:28 AM
Get the GPS on it and give us some numbers! :)
Nice car!
Big House
Big House's Avatar
05.05.2009, 10:39 PM
Monk,
Is your setup equivilant to the castle 2650 or the 2200? I plan on running the MMM 2200 on 16 and 21V geared at 20/51, metal spur of course. And I am looking for some black 4mm carbon fiber to cut my chassis. Your work has inspired me.
05.05.2009, 10:41 PM
His motor is 4400kv, and he runs it on 3s. That is equivelant to the 2200 on 6s.
FS GTP Carbon fiber chassis
phatmonk
RC carbon junkie
phatmonk's Avatar
FS GTP Carbon fiber chassis - 05.17.2009, 01:51 PM
Forsale is this new unused 1/8 inch 15 layer carbonfiber chassis.Its symetrical and wider than the original.PM me for details.Thanks
Will
ID:	7022   Click image for larger version
05.17.2009, 03:35 PM
Gotta love that guy saying that if you want to go fast you have to use maxamps...
Will
How was that chassis cut?
05.17.2009, 04:47 PM
someones birfday 2morrow................
