1st and 2nd runs = Disaster
MaxxFusion
MaxxFusion's Avatar
1st and 2nd runs = Disaster - 05.23.2005, 02:00 PM
Last weekend i finally got to take my gmaxx out. After about 5 minutes or so I saw smoke coming from the truck. I ran over and took the lid off. Here come to find that I almost completley melted through my spur gear. The slipper was too loose.
On Saturday I was was able to replace the spur gear and tightened the slipper all the way. The truck was fine then. So I was driving around the backyard taking it easy trying to get used to driving the maxx. I drives so different than my pede and rusty. I makes very wide turns. I dont know if that normal or if I have to make some adjustments. So anyway I was getting bored driving so cauction so I started getting trigger happy. Well it wasnt long after that I wrecked. I slammed into a treated 4x4 fence post that was cemented into the ground. Something had to give and it wasnt the post. Needles to say I have to rebuild work to do now.
Here is the damage done.
Snapped a RD Logic CVD
Bent the Upper Arm (Look kins of like a L)
Ripped the pillow ball right out of my RPM steering Block
Unglued all 4 tires from my rims.
Luckily I have the new version of the G# upper arms I havent put on yet. I hope that the RPM steering block is still useable. I will just have to get a new CVD and check out my steering bellcrank. I recently installed the Proline servo saver and am running the Hitec 645MG.
I will see about getting some pics of the damage.
:W:
  Send a message via MSN to MaxxFusion
HotnCold
HotnCold's Avatar
05.23.2005, 03:20 PM
Ouch.... - Man that blows hard - Your maxx was one of the nicest ones i've seen in a long while.... Those poles dont move at all do they ...
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
06.14.2005, 10:08 AM
You need more ROOM for that truck!!
Got the truck 'online' again?
MaxxFusion
MaxxFusion's Avatar
06.21.2005, 07:42 AM
No not yet. I hope to get some time this week and get her fixed up. I need to adjust my steering too. It seems like its turning too wide.
braaap11889
06.21.2005, 08:45 AM
Weak servo? Or somethings binding.
polarisguy6490
polarisguy6490's Avatar
06.25.2005, 10:05 AM
monster trucks do turn a lot wider than stampedes my friend had a stampede and it tured really sharp. You just have to get used to it i think. Otherwise what braaap said is probably the cause. (something binding/ weak servo)
Revo Project....Batteries are for flashlights
  Send a message via AIM to polarisguy6490
MaxxFusion
MaxxFusion's Avatar
06.25.2005, 12:19 PM
Its not a weak servo. Its a Hitec 645MG and I took it out of my pede.
Its most likely my pillow balls. I need to loosen them up a bit.
mmdooley
mmdooley's Avatar
06.14.2006, 03:13 PM
If your transmitter is adjustable you can make it turn tighter. I have a MX3 and It makes mine turn tight.
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
braaap11889
06.25.2005, 05:02 PM
loosen them and see if it works. The 625 aint the best servo for a MT get a stronger one like the 200oz airtronics or hiteccs new titanium gear servos peace out
servo saver
gcurtis2121
servo saver - 07.02.2005, 05:10 PM
Hey MaxxFusion, are you using a servo saver with that servo? And if so, what kind? I've got the same servo, and even though it's got metal gears, I'd rather not destroy it!
MaxxFusion
MaxxFusion's Avatar
07.02.2005, 05:42 PM
I have the Proline servo saver. Its great for the price if you can find one.
gcurtis2121
07.02.2005, 05:53 PM
Thanks, I'll go looking for one now.
braaap11889
07.02.2005, 10:52 PM
Just so you know they have been discountinued.
MaxxFusion
MaxxFusion's Avatar
07.03.2005, 02:05 PM
Yes. That is why I said if you can find one.
Here is a used one.
maxxdude1234
maxxdude1234's Avatar
07.03.2005, 02:12 PM
I believe they can only be run on the T-MAXX and Sport-MAXX, does anyone know about this? Anyone run one on an E-MAXX, if so, I'm getting one of these.
