Help with CRT part #'s
Kyosho
Help with CRT part #'s - 07.03.2009, 11:46 AM
I cant seem to find the center drive shafts for the x1 crt. if someone has the part number that would be very helpful. and also what do i need to change from 43/13 diff ratios to 43/10? do i just need the pinion?
Thanks
riverat1540
riverat1540's Avatar
07.03.2009, 01:45 PM
to do the ring and pinion conversion u need the ring and pinions from a hotbodies lightning stadium, and the center shafts part number is 40695 they are the same front and rear, also u will have to do some shimming to get the right mesh on the ring and pinions as the hot bodies pinions are a bit larger in length. hope this helps.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Kyosho
07.03.2009, 01:59 PM
my center shafts are different, the front is shorter than the back.
thanks!
