somewhat bullet proof jato tranny....
whitrzac
Can't catch this...
whitrzac's Avatar
somewhat bullet proof jato tranny.... - 06.29.2009, 01:26 PM
the pinions are 28/18...
you MUST use the stock lower shaft and file off the raised part, or drill the correct hole in the 1 speed shaft to use the 2speed diff idler gear gear...
the mod takes ~ an hour, most of the time is spent fine tuning the endplay in the bottom shaft...
make sure to use the corect pin for the plastic gear
