2 questions about hexes
Byte
2 questions about hexes - 08.08.2009, 05:06 AM
A few days ago I started a topic because I stripped my LST hexes and wanted to know how to fix it, but it went wrong Anyway, does somebody have good experience with LST1 hexes? Or should I upgrade my LST1 with a LST2 performance kit with aluminium hexes? (That would suck because I've still got 3 good tyres + rims)
And question number 2; how should I measure hexes? Losi says that the LST1 got 17mm hexes, but how the f*ck do they measure that? I measured this:
None of them is 17mm, so how do they measure 17mm? Or am I just stupid???
wallot
wallot's Avatar
08.08.2009, 05:13 AM
LST1 uses 14mm hexes :)
LST2 uses 20mm if I remmember correctly
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Byte
08.08.2009, 05:23 AM
So I measured right... (the second)
But it's still strange, if you scroll to the bottom it says the LST1 uses 17mm, but that's wrong probably...
http://www.losi.com/Articles/Article...ArticleID=1577
wallot
wallot's Avatar
08.08.2009, 05:27 AM
Old losi had maxx style axles and used to have 14mm.
Newer losi use standard 1/8 scale axles
wow just found even 14mm hexes for new style axles. they look funny.
http://www.amainhobbies.com/product_...Set-4-LST2-AFT
Radek
*EX-10 Eurus*
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.08.2009, 02:35 PM
Is that a nut? If so, then you aren't taking into account the thread in the nut, which will be 17mm when factored in.
EDIT: Okay, I have a bit of a hang over, and I realized what I said made no sense... disregard.
