new emaxx
maximum
maximum's Avatar
Smile new emaxx - 12.23.2005, 10:58 PM
Well, I ran my new emaxx for the first time after some upgrades. New shocks (powerstrokes, (60wt in bypass which I think is essentail), titanium tie rods, MIP CVD'S, 3mm skid plates, 64 tooth spur gear, Stainless Steel Hinge Pin set (which was a bitch, Damn little circlips!!!!), Aluminum Hex Hub Set, and Blue heat sinks. It was fun running up and down the street and in the neighbors lawn ( they don't mind !!!!) . I hope it runs better on the second and third run once the brushes wear in. ( I hope you people out there will tell me yes). I have yet to receive 2 C cell ni cads to make 2 seven cell packs which I hope will make a big difference in top speed. It was fun shifting gears, and i think braking regeneritive technology ( wether real or not - at least in the rc world ) is a good idea. The only problem I had was the right rear wheel had a little wobble, but after I took it off and re-attached it, it was fine. Any new experiences or problems out there with your Christmas presents let me know. I'll do the same.
