60C really?
dezfan
60C really? - 07.28.2009, 04:19 PM
http://www.maxamps.com/proddetail.ph...8-Pack&cat=218
MaxAmps.com presents the ultimate 1/8-scale hard case racing pack. As you racers know, the most important factor for your batteries is voltage under load. This LiPo pack boasts a 60C rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other LiPo battery pack on the market. Plus, you'll have no problem getting plenty of run time with 5250mah of capacity.
Perfect fit for any 1/8 scale electric vehicle that runs a single 4S pack including the Losi 8ight-E, Associated RC8-E, SC8-E and more!
- Hard Outer Case
- 5250mah Capacity
- 14.8 Volts
- 47mm X 139mm X 39mm
- 60C - 4660 surge watts(315 amps)
- 504 grams
- Water-sealed for all-weather protection
- Comes standard with Hyperion taps
- Comes standard with 12awg Deans Ultra wire
- Highest performance in the industry
- Twice the capacity of NiMH for the same weight
- Plug and Play for any charger/balancer/vehicle
- We add the connectors and balancing taps for you
- Money Back Guarantee
- Normally ships within 24-48 hours
- Exceeds safety standards of the IATA
- Built today with factory fresh cells
- Can be recharged unlimited times per day
- Copper Tab Cells for lower resistance
This should be interesting.
whitrzac
Can't catch this...
whitrzac's Avatar
07.28.2009, 04:28 PM
looks at price* I need new undiees...
maxamps rateing= 60c
real rating = 10-20c
07.28.2009, 04:31 PM
*cough* *choke* *splutter*
$250 for a 4s pack?? It better hold 3.7v/cell at 60C to be worth that price!
whitrzac: I've said it once, and I'll say it again; I'm sure that 60C spec is real (no sarcasm), but notice they do not say what the voltage will be at 60C?
whitrzac
Can't catch this...
whitrzac's Avatar
07.28.2009, 04:40 PM
I supose...
Andrew32
07.28.2009, 04:51 PM
60c surge, so i take that rating as a 30c constant and 60c burst.
translate that and i expect 20c 50c......i got my math right?
07.28.2009, 05:01 PM
I'd say 15c/25c...
drkdgglr
07.28.2009, 05:11 PM
well they do say 4660watts surge @ 315 amps(=3.7v/cell)
and on their site they explain:
Using a data logger and an actual RC motor and speed control, we test the “surge watts” by applying a load to the pack(not an individual cell) and confirming that it will maintain well over 3.2V per cell during this load. By using this method, we are confident that your MaxAmps pack will deliver the rated “surge watt” load without hitting the low voltage cutoff or damaging your pack.
07.28.2009, 05:21 PM
So... $250 for a 4s pack that MIGHT hold 3.2v/cell...
nitrostarter
nitrostarter's Avatar
07.28.2009, 05:05 PM
I say let them do their advertising and have the UNEDUCATED buy those over-rated packs....
N. Rustler conversion
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
even if it were 60c, why the 12 guage wire? can't they splurge the extra 5 cents a pack and upgrade to at least 10? i mean, if it really is 60c, lol.
Eflite Blade 400 heli on 3s
redshift
RC-Monster Square Tube
redshift's Avatar
07.28.2009, 05:22 PM
Jeez they couldn't even make a flashy new label?
I'll believe their claims when I see a 3S version start a 1:1 V8.... should do it according to their equipment right?
07.28.2009, 05:27 PM
Hmm, still, I'll believe it when I see it. Testing of my own MA packs leads me to believe otherwise (granted, they are older-generation cells). Maybe they listened to the masses and/or got tired of warranty claims and actually have cells that performed as advertised now? Still think the price tag is a bit hefty...
nitrostarter
07.28.2009, 05:30 PM
Definitely a bit hefty. I would consider trying their stuff if the price wasn't outrageous...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.28.2009, 05:41 PM
60C is just MA omitting the continuous C rating and using the surge, they are playing with the noobs here. They aren't lying or anything (although they might be), they just aren't stating the C. C rating with I'm sure is something like 30C or lower in reality.
The surge watts is BS though, that is based on the fact that a lipo cell is 3.7v/cell Nominal, they think they can do a simple calculation and multiply the nominal voltage by their so called 60C and get that number. It sickens me.
Hi Guys!
austinelse
Hi Guys! - 07.28.2009, 06:07 PM
Austin here with MaxAmps.
I understand your concerns regarding our new method of rating the packs.
However, I believe if you take the time to hear me out, you will agree that this is a much better method of providing our pack performance information than the constant "C" method.
In an effort to be more accurate and transparent, we have taken the time to articulate exactly why we are using this method and exactly how we are testing the packs to get to these figures.
Using this method, I feel that it is much, much better than just a C rate like the majority of the manufacturers are using. There is NO STANDARD TESTING METHOD TO ESTABLISH IT!
Here is the text from our lipo info page that clearly states exactly how we establish the ratings that we are using:
http://maxamps.com/lipo-care.php
