Replacing motor wires on a Neu
miniGranis
Replacing motor wires on a Neu - 01.09.2010, 06:27 AM
Hello !
Is it possible to change motor wires on a Neu 1515 DIY ?
I got a chance to by this motor for about USD 50 and if I can change the wires it might be a good deal...
Semi Pro
Semi Pro's Avatar
01.09.2010, 08:23 AM
no you cant, they are part of the windings
miniGranis
01.09.2010, 08:58 AM
Aha, I see.
Any idea on what Neu would charge to fix it ?
emaxxnitro
emaxxnitro's Avatar
01.09.2010, 01:24 PM
half of the motors initial price. but dont expect to see your motor for about 2 months
808E
Semi Pro
Semi Pro's Avatar
01.09.2010, 04:32 PM
its not worth it, to buy and get it fixed
riverat1540
riverat1540's Avatar
01.09.2010, 04:43 PM
is the wire broken or is it just exposed, u could remove the cover and re shrink it from what i can see but cant tell if its broken or not
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
phildogg
phildogg's Avatar
01.09.2010, 05:41 PM
Looks to me like the shrink wrap is slip exposing the wire. Not sure though.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
riverat1540
01.09.2010, 05:43 PM
if its not broken i would buy it and just re shrink the exposed wire and check the bearings, that looks like sand
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
01.09.2010, 08:13 PM
Indeed. Remove the old shrink, put some new glue lined stuff on & make sure it goes into the motor a little bit. Then cover those holes to prevent the motor and bearings filling up with sand- thats not good for the motor if the bearing fails, could cause the rotor to flail around inside the can, or even jam up solid..
01.10.2010, 12:25 AM
The wires look pretty black inside the can I suspect shorted
Semi Pro
Semi Pro's Avatar
01.10.2010, 03:09 AM
agreed
chumanji
01.10.2010, 04:51 AM
the motor probably has a bad stator. Anyway, NEU will charge $80 for the fix, and they will replace the bearings as well. I just had something like to done. So, like the other post said, its not worth it to buy and get it fix.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.10.2010, 10:18 AM
Pardon me for saying, who's bright idea was it to run that motor so exposed to the elements without sealing it ? Not to dam smart
TexasSP
Something, anything, nothing
TexasSP's Avatar
01.10.2010, 02:45 PM
If he buys it for 50 and spends 80 fixing it, he just got a 260 dollar motor for 130. Half price ain't a bad deal and worth it in my opinion. If it were me I would try to get the price down a little more. Maybe you can snag it for 30 then it's really worth it.
www.cubicle101.com
swiftneed
swiftneed's Avatar
02.19.2010, 11:27 PM
you can always try to do what neil said just make sure the wires are not touching any other metal surface on the can an shrink wrap it then if all else fails sent it to get fixed
