mmm up in smoke
dracbec
mmm up in smoke - 02.07.2010, 04:16 PM
i have had a mamba monster for about 6-7 months now i only have 1 setup run
on it (about 5 mins) it has been sitting on my shelf sins then becuase i
live in canada and the weather got to damp for my liking. i run 2x 8000mah
28c smc lipos with it and today i went to swap out my spektrum RX for a
telemetry RX after changing the rx i pluged in the castle link to check for
updates and updated the firmware to 1.22 after that i went to plug my batts
in and bind my RX and the esc went up in smoke and melted the the black wire
off the esc.
why did this happen i havent changed anything in the 2200kv combo sins the
setup run and now iam out of an esc?
02.07.2010, 05:24 PM
Interesting..
When the esc went up in smoke, was it before or after turning it on with the switch (after connecting the lipos )? Any chance the batts were plugged in backwards (reversed polarity )? Wasnt possibly damp inside due to condensation?
I doubt the firmware update hd anything to do with it, and it updated fine without the bec causing the castlelink to heatup rapidly, so it kinda looks like its one of those random, meaningless failures that happen upon turning the esc on..
Castle should warrenty it for you I imagine, so it will just be a little bit longer before you get to drive your truck again.
dracbec
02.08.2010, 10:17 AM
i dont think a firmware update would do that but its the only thing that was changed sins the setup run i did with it
dracbec
02.07.2010, 05:33 PM
polarity was fine and it smokes once i turned the switch on, iam itching to drive this truck it only has the 5 min setup run on it cant wait for the snow to melt, but now i maybe waiting longer
riverat1540
riverat1540's Avatar
02.07.2010, 05:38 PM
I had 2 go this way once on 6s and once on 5s with 1515 1y both times, first time it was just after i put a fresh battery in, second time esc stopped responding and i thought the switch had flopped on me so i slid it over and nothing, slid it back and it instantly started shooting flames and smoke. both times for no apparent reason, mine is now out of warranty after recent replacement and can only pray i do not lose another this way as money has been tight the way it is so it would have to sit.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
dracbec
02.07.2010, 05:54 PM
agreed it could get expensive if this keeps happening. anyone know if your warrenty starts over once you get a replacment from castle?
if it dosent then maybe if i get warrenty ill just sell it and get another brand because it is my first castle product and i havent even really run the truck yet, not saying anything bad about castle product but just my 2 cents alot of ppl love there products just my bad luck i guess.
riverat1540
02.07.2010, 05:58 PM
The warranty does not restart, u get 90 days.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Pdelcast
Pdelcast's Avatar
02.08.2010, 12:19 PM
1 year -- not 90 days.
Warranty text below:
Your Castle ESC is warranted for one (1) year from date of purchase to be free from manufacturing
and component defects. This warranty does not cover damages caused to your motor or
controller from abuse. Abuse includes, but is not limited to, the following: incorrect wiring,
over voltage, overloading, improper gearing, improper motor selection, incorrect controller
settings, insufficient batteries or connectors. If you have any questions, comments, or wish
to return your Castle ESC for warranty or non-warranty repair or replacement, please contact
Castle Creations, Inc.
Patrick del Castillo
President, Principle Engineer
riverat1540
02.08.2010, 12:31 PM
He is asking what the warranty on a replacement is. i was told 90 days on a replacement as mine was about out of warranty when it was replaced. i understand the 1 year is good from original purchase. i thought he was asking what the warranty of a replacement is if the original warranty is about expired.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Pdelcast
Pdelcast's Avatar
02.08.2010, 01:00 PM
Oh, that's correct - -sorry I misunderstood. 90 days for an advance warranty replacement. Those are usually reserved for things like DOA, shipping damage, etc.
Thanx!
Patrick
dracbec
02.08.2010, 02:50 PM
Hey Patrick is this a known problem with the monster or did i just have bad luck and get the one out of every hundred that has problems?
Pdelcast
Pdelcast's Avatar
02.08.2010, 02:55 PM
No, from your description, it sounds to me like one of the FET drivers gave up the ghost. It's not a typical failure mode. We only see a handful that fail in that manner.
Patrick
